06 cobalt charging issues - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 3 (permalink) Old 07-24-2016, 07:47 PM Thread Starter
OK so I have a 06 cobalt ss lsj. I have recently started having a problem where the alternator is not charging the battery I have already put 2 different alternator on and changed the ecu. When I backprobed the connector on alternator it was putting out 4.3 volts with the car running. Any help is greatly appreciated I dont know what else to do thank you
Blackbalt06 is offline
post #2 of 3 (permalink) Old 07-26-2016, 11:29 AM
As i can't find a wiring diagram for the car myself this may or may not help but I believe the charge wire out of the Alt goes to the top stud on the starter where it gets connected to the battery cable leading up to the post on the fuse box to join the main lead back to the trunk.
If the ~ 10agw wire is broken or suffered corrosion you may not be charging due to the lack of voltage sensing off the charge wire.
Have you done anything in the starter area lately?
05 Cobalt SS 100% stock.
"Smok'in the competition NOT Tobacco"
"Transplant organs, Don't bury them!"
Anthony Leary is offline
post #3 of 3 (permalink) Old 07-26-2016, 09:50 PM Thread Starter
Yes I did change the starter about a month ago and I also had to change the crank sensor and take the starter out to do so
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
twin charging Lil-devil86 Performance Modifications 3 06-05-2008 07:03 PM
Cobalt Storage Issues rlinden86 General Discussion 1 11-14-2006 11:12 AM
More power ss/sc??Twin charging? 1namillion Performance Modifications 21 07-17-2006 09:08 PM
Twin charging orange06ss Performance Modifications 35 05-08-2006 08:57 PM
twin charging SS_mike Performance Modifications 4 11-22-2005 05:22 PM
