2005 Cobalt SS DTC List - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 3 (permalink) Old 07-07-2005, 04:14 PM Thread Starter
WopOnTour's Avatar
Here is a complete list of ALL POSSIBLE DTCs that can be present in a 2005 Cobalt SS/SC (w/ LSJ) and the modules in whch the DTC may be stored.
Enjoy
WopOnTour
DTC DTC Description -Module/s That Sets the DTC
B0012 Driver Frontal Deployment Loop Stage 1 -SDM
B0013 Driver Frontal Deployment Loop Stage 2 -SDM
B0015 Left Front Seat Belt Pretensioner Deployment Loop -SDM
B0016 Left Roof Rail Deployment Loop -SDM
B0019 Passenger Frontal Deployment Loop Stage 1 -SDM
B0020 Passenger Frontal Deployment Loop Stage 2 -SDM
B0022 Right Front Seat Belt Pretensioner Deployment Loop -SDM
B0023 Right Roof Rail Deployment Loop -SDM
B0052 Deployment Commanded -SDM
B0053 Deployment Commanded with Loop DTCs present -SDM
B0055 Side Air Bag Deployment Commanded -SDM
B0083 Front End Sensor 1 -SDM
B0085 LF/Driver Side Impact Sensor -SDM
B0086 RF/Passenger Side Impact Sensor -SDM
B0158 Outside Air Temperature Sensor -HVAC
B0285 Electric Rear Defrost Circuit Low -BCM
B1000 Electronic Control Unit (ECU) Performance -BCM, DRR, IPV, Radio, SDM, VCIM
B1001 Option Configuration Error -DRR, Radio, SDM
B1004 Keep Alive Memory (KAM) Reset -BCM, DRR, IPC
B1009 EEPROM Checksum Mismatch -BCM, Radio
B1019 System Configuration Error -SDM
B1025 LF Audio Output Circuit -Radio
B1035 RF Audio Output Circuit -Radio
B1045 LR Audio Output Circuit -Radio
B1055 RR Audio Output Circuit -Radio
B1325 Device Power 1 Circuit -BCM, IPC, Radio, SDM
B1370 Device Ignition 1 Circuit -BCM, SDM
B1380 Device Ignition ACCESSORY Circuit -BCM
B1441 Device Ignition OFF, RUN, and CRANK Circuit -BCM
B1480 Battery Rundown Protection Circuit -BCM
B1516 Battery Current Sensor Performance -BCM
B1517 Battery Voltage -IPM
B2455 Cellular Phone Microphone Circuit Malfunction -VCIM
B2470 Cellular Phone Antenna Circuit Malfunction -VCIM
B2476 Cellular Phone Select Service Switch Malfunction (3-button assembly) -VCIM
B2482 Cellular Phone Select Switch Range/Performance -VCIM
B2483 GPS Sensor Circuit Low -VCIM
B2484 GPS Sensor Circuit Open -VCIM
B2530 Front Fog Lamps Control Circuit -BCM
B2580 Headlamp High Beam Control Circuit -BCM
B2625 Display Dimming Pulse Width Modulation (PWM) Output Circuit -BCM
B2645 Ambient Light Sensor Circuit -BCM
B2705 Gearshift Unlock Circuit -BCM
B2750 Horn Relay Output -BCM
B2955 Security System Sensor Data Circuit -BCM
B2960 Security System Sensor Data Incorrect but Valid -BCM
B2961 Key In Ignition Circuit -BCM
B3031 Security System Controller In Learn Mode -BCM
B3033 Security System Indicates Tamper -BCM
B3100 X Link Programming/Diagnostic mode acknowledge message not received -BCM
B3109 Keyless Entry Transmitter Low Battery -BCM
B3127 Left Front/Driver Door Only Unlock Circuit Low -BCM
B3132 All Door Unlock Circuit Low -BCM
B3137 All Door Lock Circuit Low -BCM
B3265 Trunk Relay Output -BCM
B3715 Front Wiper Relay Drive Circuit -BCM
B3716 Front Wiper Relay Drive Circuit Range/Performance -BCM
B3717 Front Wiper Relay Drive Circuit Low -BCM
B3718 Front Wiper Relay Drive Circuit High -BCM
B3719 Front Wiper Relay Drive Circuit Open -BCM
B3794 Cruise Control Function Request Circuit -BCM
B3903 Stop Lamp Relay Circuit -BCM
B3948 Left Front Turn Signal Circuit -BCM
B3949 Right Front Turn Signal Circuit -BCM
B3950 Left Rear Turn Signal Circuit -BCM
B3951 Right Rear Turn Signal Circuit -BCM
C0000 Vehicle Speed Information Circuit -PSCM
C0035 LF Wheel Speed Sensor Circuit -EBCM
C0040 RF Wheel Speed Sensor Circuit -EBCM
C0045 LR Wheel Speed Sensor Circuit -EBCM
C0050 RR Wheel Speed Sensor Circuit -EBCM
C0110 Pump Motor Circuit -EBCM
C0116 Pump Motor Relay Circuit -EBCM
C0121 Valve Relay Circuit -EBCM
C0161 ABS/TCS Brake Switch Circuit -EBCM
C0176 System Thermal Error -PSCM
C0220 Left Front ABS Channel in Release Too Long -EBCM
C0221 Right Front ABS Channel in Release Too Long -EBCM
C0228 Left Rear ABS Channel in Release Too Long -EBCM
C0229 Right Rear ABS Channel in Release Too Long -EBCM
C0240 PCM Traction Control Not Allowed -EBCM
C0242 PCM Indicated TCS Malfunction -EBCM
C0281 Dynamic Rear Proportioning (DRP) Performance -EBCM
C0475 Electric Steering Motor Circuit -PSCM
C0545 Steering Wheel Torque Input Sensor -PSCM
C0550 Electronic Control Unit (ECU) Performance -EBCM
C0552 Improper Shutdown -EBCM
C0561 System Disabled Information Stored -EBCM
C0845 Device Ignition 1 Circuit -PSCM
C0895 Device Voltage -PSCM
C0899 Device Voltage Low -EBCM
C0900 Device Voltage High -EBCM
P0030 HO2S Heater Control Circuit Sensor 1 -PCM
P0033 Supercharger Bypass Valve Solenoid Control Circuit -PCM
P0036 HO2S Heater Control Circuit Sensor 2 -PCM
P0068 Throttle Body Airflow Performance -PCM
P0069 Supercharger Inlet Pressure (SCIP) - Barometric (BARO) Pressure Correlation -PCM
P0097 Intake Air Temperature (IAT) Sensor 2 Circuit Low Voltage -PCM
P0098 Intake Air Temperature (IAT) Sensor 2 Circuit High Voltage -PCM
P0101 Mass Air Flow (MAF) Sensor Performance - PCM
P0102 Mass Air Flow (MAF) Sensor Circuit Low Frequency -PCM
P0103 Mass Air Flow (MAF) Sensor Circuit High Frequency -PCM
P0106 Manifold Absolute Pressure (MAP) Sensor Performance -PCM
P0107 Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage -PCM
P0108 Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage -PCM
P0112 Intake Air Temperature (IAT) Sensor 1 Circuit Low Voltage -PCM
P0113 Intake Air Temperature (IAT) Sensor 1 Circuit High Voltage -PCM
P0117 Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage -PCM
P0118 Engine Coolant Temperature (ECT) Sensor Circuit High Voltage -PCM
P0120 Throttle Position (TP) Sensor 1 Circuit -PCM
P0121 Throttle Position (TP) Sensor 1 Performance -PCM
P0122 Throttle Position (TP) Sensor 1 Circuit Low Voltage -PCM
P0123 Throttle Position (TP) Sensor 1 Circuit High Voltage -PCM
P0125 Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control -PCM
P0128 Engine Coolant Temperature (ECT) Below Thermostat Regulating -PCM
P0130 HO2S Circuit Sensor 1 -PCM
P0131 HO2S Circuit Low Voltage Sensor 1 -PCM
P0132 HO2S Circuit High Voltage Sensor 1 -PCM
P0133 HO2S Slow Response Sensor 1 -PCM
P0134 HO2S Circuit Insufficient Activity Sensor 1 -PCM
P0135 HO2S Heater Performance Sensor 1 -PCM
P0136 HO2S Circuit Sensor 2 -PCM
P0137 HO2S Circuit Low Voltage Sensor 2 -PCM
P0138 HO2S Circuit High Voltage Sensor 2 -PCM
P0140 HO2S Circuit Insufficient Activity Sensor 2 -PCM
P0141 HO2S Heater Performance Sensor 2 -PCM
P0171 Fuel Trim System Lean -PCM
P0172 Fuel Trim System Rich -PCM
P0201 Injector 1 Control Circuit -PCM
P0202 Injector 2 Control Circuit -PCM
P0203 Injector 3 Control Circuit -PCM
P0204 Injector 4 Control Circuit -PCM
P0220 Throttle Position (TP) Sensor 2 Circuit -PCM
P0222 Throttle Position (TP) Sensor 2 Circuit Low Voltage -PCM
P0223 Throttle Position (TP) Sensor 2 Circuit High Voltage -PCM
P0230 Fuel Pump Relay Control Circuit -PCM
P023A Charge Air Cooler (CAC) Coolant Pump Relay Control Circuit -PCM
P0300 Engine Misfire Detected -PCM
P0301 Cylinder 1 Misfire Detected -PCM
P0302 Cylinder 2 Misfire Detected -PCM
P0303 Cylinder 3 Misfire Detected -PCM
P0304 Cylinder 4 Misfire Detected -PCM
P0315 Crankshaft Position (CKP) System Variation Not Learned -PCM
P0325 Knock Sensor (KS) Circuit -PCM
P0326 Knock Sensor (KS) Performance -PCM
P0327 Knock Sensor (KS) Circuit Low Voltage -PCM
P0335 Crankshaft Position (CKP) Sensor Circuit -PCM
P0336 Crankshaft Position (CKP) Sensor Performance -PCM
P0340 Camshaft Position (CMP) Sensor Circuit -PCM
P0341 Camshaft Position (CMP) Sensor Performance -PCM
P0351 Ignition Coil 1 Control Circuit -PCM
P0352 Ignition Coil 2 Control Circuit -PCM
P0353 Ignition Coil 3 Control Circuit -PCM
P0354 Ignition Coil 4 Control Circuit -PCM
P0420 Catalyst System Low Efficiency -PCM
P0442 Evaporative Emission (EVAP) System Small Leak Detected -ECM, PCM
P0443 Evaporative Emission (EVAP) Purge Solenoid Control Circuit -PCM
P0446 Evaporative Emission (EVAP) Vent System Performance -PCM
P0449 Evaporative Emission (EVAP) Vent Solenoid Control Circuit -PCM
P0451 Fuel Tank Pressure (FTP) Sensor Performance -PCM
P0452 Fuel Tank Pressure (FTP) Sensor Circuit Low Voltage -PCM
P0453 Fuel Tank Pressure (FTP) Sensor Circuit High Voltage -PCM
P0454 Fuel Tank Pressure (FTP) Sensor Circuit Intermittent -PCM
P0455 Evaporative Emission (EVAP) System Large Leak Detected -PCM
P0461 Fuel Level Sensor Performance -PCM
P0462 Fuel Level Sensor Circuit Low Voltage -PCM
P0463 Fuel Level Sensor Circuit High Voltage -PCM
P0480 Cooling Fan Relay 1 Control Circuit -PCM
P0481 Cooling Fan Relay 2 Control Circuit -PCM
P0482 Cooling Fan Relay 3 Control Circuit -PCM
P0496 Evaporative Emission (EVAP) System Flow During Non-Purge -PCM
P0502 Vehicle Speed Sensor (VSS) Circuit Low Voltage -PCM
P0503 Vehicle Speed Sensor (VSS) Circuit Intermittent -PCM
P0506 Idle Speed Low -PCM
P0507 Idle Speed High -PCM
P0520 Engine Oil Pressure (EOP) Sensor Circuit -PCM
P0532 (A/C) Air Conditioning Pressure Sensor Circuit Low Voltage -PCM
P0533 (A/C) Air Conditioning Pressure Sensor Circuit High Voltage -PCM
P0562 System Voltage Low -PCM
P0563 System Voltage High -PCM
P0601 Control Module Read Only Memory (ROM) -PCM
P0602 Control Module Not Programmed -PCM
P0603 Control Module Long Term Memory Reset -PCM
P0604 Control Module Random Access Memory (RAM) -PCM
P0605 Control Module Programming Read Only Memory (ROM) -PCM
P0606 Control Module Internal Performance -PCM
P0607 Control Module Performance -PCM
P060E Control Module Throttle Position (TP) System Performance -PCM
P0621 Generator L-Terminal Circuit -PCM
P0622 Generator F-Terminal Circuit -PCM
P0641 5-Volt Reference 1 Circuit -PCM
P0650 Malfunction Indicator Lamp (MIL) Control Circuit -PCM
P0651 5-Volt Reference 2 Circuit -PCM
P0719 Brake Switch Circuit Low Voltage -PCM
P0724 Brake Switch Circuit High Voltage -PCM
P0833 Clutch Pedal Switch 2 Circuit -PCM
P1101 Intake Air Flow System Performance -PCM
P1106 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage -PCM
P1107 Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage -PCM
P1111 Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage -PCM
P1112 Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage -PCM
P1114 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage -PCM
P1115 Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage -PCM
P1133 HO2S Insufficient Switching Sensor 1 -PCM
P1182 Supercharger Inlet Pressure Sensor Performance -PCM
P1183 Supercharger Inlet Pressure Sensor Circuit Low Voltage -PCM
P1184 Supercharger Inlet Pressure Sensor Circuit High Voltage -PCM
P1258 Engine Coolant Over Temperature - Fuel Disabled -PCM
P1516 Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance -PCM
P1574 Stop Lamp Switch Circuit -PCM
P1600 Control Module Long Term Memory Reset -PCM
P1621 Control Module Long Term Memory Performance -PCM
P1626 Theft Deterrent Fuel Enable Signal Lost -PCM
P1627 Control Module Analog to Digital Performance -PCM
P1630 Theft Deterrent Learn Mode Active -PCM
P1631 Theft Deterrent Start Enable Signal Not Correct -PCM
P1633 Ignition 0 Switch Circuit -PCM
P1680 Control Module Accelerator Pedal Position (APP) System Performance -PCM
P1681 Control Module Throttle Position (TP) System Performance -PCM
P1682 Ignition 1 Switch Circuit 2 -PCM
P1683 Control Module Ignition Off Timer Performance -PCM
P1700 Transmission Control Module (TCM) Requested MIL Illumination -PCM
P2101 Throttle Actuator Position Performance -PCM
P2119 Throttle Closed Position Performance -PCM
P2120 Accelerator Pedal Position (APP) Sensor 1 Circuit -PCM
P2122 Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage -PCM
P2123 Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage -PCM
P2125 Accelerator Pedal Position (APP) Sensor 2 Circuit -PCM
P2127 Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage -PCM
P2128 Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage -PCM
P2135 Throttle Position (TP) Sensor 1-2 Correlation -PCM
P2138 Accelerator Pedal Position (APP) Sensor 1-2 Correlation -PCM
P2176 Minimum Throttle Position Not Learned -PCM
P2227 Barometric Pressure (BARO) Sensor Performance -PCM
P2228 Barometric Pressure (BARO) Sensor Circuit Low Voltage -PCM
P2229 Barometric Pressure (BARO) Sensor Circuit High Voltage -PCM
P2535 Ignition 1 Switch Circuit High Voltage -PCM
P2610 Control Module Ignition Off Timer Performance -PCM
U0001 High Speed CAN Communication Bus -PCM
U1300 Class 2 Data Link Low -PCM
U1301 Class 2 Data Link High -PCM
U1305 Class 2 Data Link Low or High -PCM
U1500 Inter-Device Dedicated Bus Malfunction -VCIM
U2100 Controller Area Network (CAN) Bus Communication -BCM, EBCM, IPC, PCM, PSCM, Radio, SDM,VCIM
U2103 Fewer Controllers On Bus Than Programmed -IPC, Radio, SDM, VCIM
U2105 Lost Communications with Engine Control System -BCM, EBCM, PSCM
U2106 Lost Communications with Transmission Control System -BCM, EBCM, PSCM
U2107 Lost Communications with Body Control System -EBCM, IPC, PCM
U2108 Lost Communications with ABS/TCS Control System -BCM
U2109 Lost Communications with Powertrain Multiple Control System -EBCM, PSCM
U2111 Lost Communications with Steering Control System -BCM
U2113 Lost Communications with Sensing Diagnostic Module (SDM) -BCM
U2116 Lost Communications with Instrument Panel Cluster (IPC) -BCM, PSCM
U2125 Lost Communications with Mobile Communications Control Systems -BCM
B- Body System DTCs
C- Chassis System DTCs
P- Powertrain System DTCs
U- Network System DTCs
BCM - Body Control Module
EBCM - Electronic Brake Control Module
IPC - Instrument Panel Cluster
PCM - Powertrain Control Module
PSCM - Power Steering Control Module
SDM - Sensing Diagnostic Module (airbags)
VCIM - Vehicle Communication Interface Module (OnStar)
WopOnTour is offline
post #2 of 3 (permalink) Old 11-21-2015, 02:05 AM
What I read I really liked it. Thank you for your information!
Ominto is offline
post #3 of 3 (permalink) Old 01-06-2016, 12:09 AM
this post should be pinned
Speedometer is offline
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
