ZZP Header - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 23 (permalink) Old 06-18-2007, 01:14 PM Thread Starter
ZZP Header
Well, my zzp shorty header will be here tomorrow. I am really excited about getting it put on. Will I notice a significant difference from the stock manifold????? It might seem late to ask, but I knew I wanted a header and didn't want the gmpp manifold. So will I notice a big difference, and if so, where in the power band???
2006 Black G85 Cobalt SS/SC
241 WHP 228 lbs/ft (Before header,dp, exhaust, and 2.9 pulley)
GM Stage 2 (with Nate's 2.9 pulley)
K&N Typhoon Intake
ZZP Mid length combo (1.75 primaries, 2.5 dp w/ hf cat)
Custom Magnaflow 2.5 catback exhaust w/ whisper resonator
B&M short throw shifter w/ stock knob
Ingalls Engine Torque Dampener
[U]Coming Soon: Cooling, Tune, lowering springs
jwolf8604 is offline
post #2 of 23 (permalink) Old 06-20-2007, 06:58 PM Thread Starter
Comon guys.....Will I feel torque or hp with this header??????? ....or both
K&N Typhoon Intake
post #3 of 23 (permalink) Old 06-20-2007, 08:15 PM
Doc
Doc's Avatar
you'll notice both....nothing extreme.
Proud DSLSJA Member
Doc is offline
post #4 of 23 (permalink) Old 06-22-2007, 07:50 AM Thread Starter
First off, I love the header. I'm taking it back to the guy who put it on cause there were some problems. When my engine torqes down, my downpipe (stock one) is rubbing up against something (can't tell what it is). My heat sheild is also missing a screw and there is a very obnoxious ticking noise (maybe an exhaust leak). Other than that, I am really satisfied with the header.
K&N Typhoon Intake
post #5 of 23 (permalink) Old 06-22-2007, 06:48 PM
Doc
Doc's Avatar
I bet its rubbing on the sway bar....you can see it if you look through the engine bay, following the downpipe down where it crosses over the sway bar. Hopefully it isn't the coolant tube that crosses close by.
Proud DSLSJA Member
Doc is offline
post #6 of 23 (permalink) Old 06-22-2007, 07:16 PM
You might want to get that looked at and fixed. I know in the GTP world, the downpipe hitting the sway bar would cause false knock and pull timing = Less Power. Not sure if this can do the same on a cobalt?
KlugSRT-4v2 is offline
post #7 of 23 (permalink) Old 06-22-2007, 08:25 PM
my brother had a gtp a while ago and that was happening. we fixed it by flipping the sway bar upside down.
SuperSlow07 is offline
post #8 of 23 (permalink) Old 06-23-2007, 02:29 AM Thread Starter
Yea, the downpipe was vibrating against the sway bar when my engine would torque down. Got it fixed, and one of the bolts on the left port was loose causing the exhaust leak. He fixed both today, and offered me a gatorade and a ride in his 03 SVT Cobra (Convertable w/ 450 whp). We called it even.
K&N Typhoon Intake
post #9 of 23 (permalink) Old 06-23-2007, 08:08 AM
Send a message via AIM to matt_SS_205
so did you notice much of a performance gain with the header?
FASTEST DSJSJA MEMBER: 13.5 @ 104
Performance: GM Stage 2, 2.9, Vibrant Header D/P, Injen CAI, GMPP Performance Cat-Back, Custom Tuned, BWoody trans mount, Ingalls Torque Damper Hurst Short Throw
matt_SS_205 is offline
post #10 of 23 (permalink) Old 06-23-2007, 10:20 AM Thread Starter
Absolutely. Like doc said, it is nothing dramatic, but it gives your exhaust a little bit better tone (I still have stock exhaust). You notice an increase in torque and in horsepower and the car sounds mean, even with stock exhaust. Not too loud, just sounds angry and feels like it flows better. I would def. reccomend!
K&N Typhoon Intake
Human Verification
In order to verify that you are a human and not a spam bot, please enter the answer into the following box below based on the instructions contained in the graphic.
2.4 header???? WhiteSS Performance Modifications 3 11-10-2013 04:44 PM
Zzp Header jwolf8604 Performance Modifications 0 05-09-2007 05:39 PM
WTB: Header redline13 Parts Wanted/Parts for Sale 2 10-07-2006 01:42 PM
shorty header vs. long tube header WhiteSS Performance Modifications 1 09-12-2006 10:40 AM
header?? moose Performance Modifications 4 06-19-2006 11:43 PM
