Rear spoilers are one of the most popular auto accessories available on the aftermarket. From mild to wild, a rear spoiler can change the entire look of any vehicle. If you want the spoiler, which after mounting has a factory installed look, then the factory style spoiler is exactly you need. We have 2 exclusive options from Pure and JKS, designed for the Chevy Cobalt 2010, which you might find interesting.
Pure® - Factory Style Rear Spoiler will perfectly complement your car's fine lines, and its distinctive shape will set your car apart from lesser models. It delivers a sporty image that is easy to be recognized. Made from Fiberglass, installs easily with screws and gaskets, backed by a 3-year warranty. You can use it for better traction and to add a sporty look, but also include other advantages, such as increased fuel efficiency, added visibility, reduced car weight, and braking stability.
[URL="JKS® - Factory Style Rear Spoiler"]JKS® - Factory Style Rear Spoiler[/URL] enhance vehicle's exterior as well as improve its maneuverability. It helps to give your car the same look as the high-performance models. It improves aerodynamics, has factory style, made from ABS plastic and installs easily with screws and gaskets.
Both spoilers are available in Unpainted and Painted versions (you can check the paint code by VIN# or with paint code labels, located at the driver side door jamb).
If you want to discover more information about those brand click here:
Pure http://www.carid.com/pure/
JKS http://www.carid.com/jks/
Check prices for your model and see other details here: http://www.carid.com/2010-chevy-cobalt-spoiler/
