Rear Speaker Wiring Polarity - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
Mark Forums Read
Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums > Cobalt SS Discussion > General Discussion
Thread Tools Display Modes
Old 07-25-2005, 09:13 PM   #1
BlackSS
I'm trying to hook up a line output convertor to my rear 6x9 speaker wires in my SS. It's got the MP3 player in it and I want to hook up a couple subs. Can anyone tell me which wires are posative and negative in the rear?
__________________
2005 Cobalt SS/SC
UNDER CONSTRUCTION
BlackSS is offline   Reply With Quote
Old 07-25-2005, 10:10 PM   #2
selfinfliction
i'm hoping you aren't going to plug up subs to the factory wires coming from the radio........
selfinfliction is offline   Reply With Quote
Old 07-25-2005, 10:29 PM   #3
Dan Richards
Dan Richards's Avatar
The big spade is always (+).
__________________
2001 Monte Carlo SS High Sport - Galaxy Silver - Not Stock
Dan Richards is offline   Reply With Quote
Old 07-26-2005, 05:38 AM   #4
BlackSS
Like I said, I'm hooking up a line output converter so I can run RCA jacks to my amps. I am experienced hooking up stereos and subs. I just need to know what wire is what. There isn't one spade bigger than the other one.
Thanks
__________________
2005 Cobalt SS/SC
UNDER CONSTRUCTION
Old 07-26-2005, 07:14 AM   #5
ericsean
ericsean's Avatar
Left rear: negative is yellow/black Positive is brown / black
Right Rear: Light blue / black positive is dark blue / black
They are striped. This should be accurate unless there was a design change after the wiring diagrams were created.
edit: an easy way to tell would be to get a volt meter and measure the polarity between the wires while the unit is sending a signal.
__________________
'05 Victory Red Cobalt SS
XM, Side Curtain Bags, $15 Lighter / Ashtray
ericsean is offline   Reply With Quote
Old 07-26-2005, 08:11 AM   #6
orange juice
orange juice's Avatar
GM's have always used this formula unless they for whatever reason changed this for 05+ cars:
Light up front, dark in the rear.
That means the light tone colors up front are positive and the dark colored tones in the rear are the positives for them.
-ex installer
orange juice is offline   Reply With Quote
Old 07-26-2005, 10:54 AM   #7
BlackSS
Do you guys happen to know where I can get the 12 VOLT swithced power for the amp turn on in the rear of the car?
__________________
2005 Cobalt SS/SC
UNDER CONSTRUCTION
Old 07-26-2005, 01:22 PM   #8
ericsean
ericsean's Avatar
I just have wiring diagrams, not locations of harnesses, sorry. The battery feeds into the Underhood BEC then into the BCM, followed by the amplifier, and finally to the speakers / subwoofer. The BEC is in the engine compartment, the BCM and the AMP are in the I/P ( Instrument Panel ) area. The wires for this system go all over the place, from the trunk (batt) to the BEC ( engine compartment ) to the I/P and back to the, for the case of the sub, the trunk again.
__________________
Old 07-26-2005, 01:46 PM   #9
selfinfliction
yeah if you have an ss, there is an empty fuse holder.. like 10, 11 or 12... i'll have to double check today. it's for some kind of lights on an autoomatic, it's where i have my water injection kit plugged up to... i'm not sure if the fuseblock on the inside of the car actually has any open slots
Old 07-26-2005, 02:41 PM   #10
BlackSS
OK, if you could check for me that would be great.
Thanks
__________________
2005 Cobalt SS/SC
UNDER CONSTRUCTION
Gear in this thread - Powered by O'Reilly Auto Parts
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
© AutoGuide
