tightening the e-brakes - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
Mark Forums Read
» Auto Insurance
» Featured Product
» Wheel & Tire Center
Go Back   Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums > Cobalt SS Discussion > Wheels, Tires, Brakes, and Suspension
Thread Tools Display Modes
Old 08-19-2011, 08:01 AM   #1
marioc89
Has anybody tightened their emergency brakes before, if so, how easy is it and what 's the procedure? Thanks!
marioc89 is offline   Reply With Quote
Old 08-19-2011, 09:35 AM   #2
RedSStreak
You do not have any drum brakes in the rear hub so the only way to do it is to tighten the cable. And for these vehicles, according to all the mechanics and personal friends that are mechanics do not recommend that. Only for the sole purpose that if you tighten too much, it could be engaged all the time slight enough to wear your pads prematurely and you will have the same issue all over again. The need to adjust it. The best thing to do is to inspect the rear brakes and if they are low, upgrade your rear rotors to drilled or slotted and change the pads to your choosing.
__________________
Any questions about the Balt, all answered here:
http://camaroforums.com/forum/projec...26/#post620429
RedSStreak is offline   Reply With Quote
Old 08-19-2011, 05:50 PM   #3
Mentalm
Mentalm's Avatar
i did it in my tc a few weeks ago. i just slid the ebrake cover off and tightened the bolt beside it it was seriously just hanging there loose. i think the bolt backs off over time all i know is the brake is maxed out when pulled for it to grab yet again alredy... now if thats the way to do it im not sure i just saw a how to and decided to try it all i did was tighten the bolt till the nut was wobbley i guess is the best way to put it. basicly made it snug.... it made my ebrake grab alot sooner and better for a few weeks but now its the same issue so maybe give that a try?
__________________
35% tint sides and rear
GM Sport pedals
Mentalm is offline   Reply With Quote
Old 08-20-2011, 07:39 PM   #4
marioc89
What are my options if I don't want to upgrade or anything? What part of the cable do I adjust it at?
Old 08-22-2011, 11:44 AM   #5
RedSStreak
I have no clue, only downfall to owning the Balt, not a good e-brake from factory....
__________________
Old 09-11-2011, 12:43 PM   #6
marioc89
Well, I think on my version of the cobalt, I think they're self adjusting...I could be wrong and somebody correct me if I am. But what's happening with mine is that when I disengage my ebrakes, they don't fully detract or disengage because I could feel it dragging. I have to manually disengage it with my hands by getting under the car. Is there something I need to grease or what?
Old 09-12-2011, 03:28 PM   #7
RedSStreak
Could be a couple of things. I would take it in to a brake shop to have it looked at because there isn't enough info to suggest a solution except to do a multi-point inspection on your brakes.
__________________
Old 09-12-2011, 05:24 PM   #8
Mentalm
Mentalm's Avatar
the pin the i forget i think it lifts up by the clamp that turns when u pull up the e-brake. that needs to be regressed when u have that issue. sounds like its staying stuck. if u look at the rear wheels u can see the pins im talking about hopefully u get what i mean. now im not the most car savey guy but ive read and seen it discussed alot.
__________________
GM Sport pedals
Old 09-13-2011, 05:15 PM   #9
marioc89
I'm sorry dude, I don't know what you mean. I have a circular clip spring not the long spring just so you know.
Old 09-14-2011, 03:13 PM   #10
Mentalm
Mentalm's Avatar
ill see if i can get pictures but may be late next week. at the soonest
*from what ive been told and read the cobalts e-brake is self adjusting the only adjustment i know that can be made is if you remove the plastic e-brake cover theres a 10mm bolt that u tighten and it does something cause ive done it on mine which wasnt grabing and now it is. and has been for a few days . u removed the middle trim peace / rear cup holders / ebrake plastic cover. and its right there raise and drop the e-brake a few times to settle the hardware. the tighten the bolt u may have to tighten the bolt a few times with the ebrake raised then lower it and tighten it untill it finaly grabs at a normal height
__________________
GM Sport pedals
You may not post new threads
You may not post replies
Forum Jump
Brakes--need new ones or not? Gonetoofar Wheels, Tires, Brakes, and Suspension 6 06-01-2011 06:41 PM
Brakes locking up 06 stlss Problems/Dealer Service 3 02-28-2011 04:22 PM
brakes 0cobaltss9 General Discussion 0 11-15-2009 10:24 PM
SSBC brakes? stiggonometry15 Performance Modifications 6 04-15-2006 11:44 PM
brakes cerbomark Problems/Dealer Service 13 04-29-2005 04:12 PM
Powered by vBulletin®
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
© AutoGuide
