how to change headlight bulbs? - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
Mark Forums Read
Auto Insurance
» Featured Product
Wheel & Tire Center
Go Back   Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums > Cobalt SS Discussion > General Discussion
Thread Tools Display Modes
Old 05-12-2006, 06:43 PM   #1
blacklock
I did a search and could not come up with an answer. I just want to know, do I have to pull the whole headlight to change the bulb or is there some kind of trick to getting at the bulbs
blacklock is offline   Reply With Quote
Old 01-30-2007, 06:52 PM   #2
felix2388
im stuck there too, i have no idea how to get the bulb out past removing the wires
__________________
Have
Dry Charged Fujita CAI ~ Ingall TQ Brace ~ GM Stage 2 ~ B&M Short Shifter ~ Control Arm Bushing ~ NGK Colder Spark Plugs ~ Spec Stage 2+ Clutch ~ Fidanza Flywheel
On It's Way!
DC SB
Ordering
Pending...
felix2388 is offline   Reply With Quote
Old 01-30-2007, 08:27 PM   #3
HeppyCat
HeppyCat's Avatar
im curious blacklock, have you had a bulb go out? how lon ghave you had the car?
HeppyCat is offline   Reply With Quote
Old 01-30-2007, 08:32 PM   #4
suprchged
Well you have to take the light out otherwise you can get the leverage to get out the assembly, the light sets in a housing and you have to turn it to free it after that just get in there and you will see how to do it, dont forget to use electrical grease so you dont get corrosion.
suprchged is offline   Reply With Quote
Old 01-30-2007, 08:52 PM   #5
JohnsRallyYellowSS
Ive found it a lot easier to use some body-work spatulas (soft plastic) to stick around the headlight so when you pull it out, the bumper slides under the housing, and it doesnt scratch the paint! And yes, use di-electric grease on the connection to avoid any future problems!
__________________
DSLSJA Member
-GM Stage 2
-NHerbst 2.9" billet pulley
-K&N Typhoon Intake
-Ingalls TD
-RiceEater Strut tower brace
-RiceEater Rear Stabilizer bar
-Custom plug wire cover
-7k NOKYA Arctic white bulbs
-Dash inserts painted to match
ASE Certified P2 Parts Specialist
www.myspace.com/camaro327rs
"You can polish a turd, but its still a turd!!!"
JohnsRallyYellowSS is offline   Reply With Quote
Old 01-31-2007, 07:57 PM   #6
Kenhebe
I manage a paint and body shop and had to do this to color match paint my headlamps here is what yo uneed to do.
(1) Remove all plastic clips (4) that attatch the bumper cover to the radiator support. The radiator support is the thing your hood latch is attatched to.
(2) Loosen the 10mm bolts that attatch the front fenders to the car. There is one near the headlamp and one near the hood hinges. Do not remove them completely, but get as close as you can.
(3) Loosen the 2 10 mm bolts that attatch the headlamp to the fiberglass mounting bracket.
(4) Carefully pull the portion of the headlamp that attatches to the fender out and you are finished.
Kenhebe is offline   Reply With Quote
Gear in this thread - Powered by O'Reilly Auto Parts
You may not post new threads
You may not post replies
Forum Jump
Powered by vBulletin®
Copyright ©2000 - 2016, Jelsoft Enterprises Ltd.
© AutoGuide
