P1174 Dtc - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 7 (permalink) Old 08-20-2009, 10:49 AM Thread Starter
P1174 Dtc
2006 Colbalt sedan with 2.4L engine. 106K miles and the MIL came on with the subject DTC. I had the injectors and fuel filter changed in Dec 08. Mechanic stated now the injectors are fine, replaced the fuel filter again and told me to run premium for a few tanks to see if the code clears.
Any other ideas what can be wrong?
Frenchman is offline
post #2 of 7 (permalink) Old 08-20-2009, 05:16 PM
knock?????
post #3 of 7 (permalink) Old 08-21-2009, 05:12 AM Thread Starter
P1174
No knocking, only the light came on. In December before the injectors were replaced, the car would shudder intermittently at highway speed. After the injectors were replaced the MPG improved significantly (29 before, now 34-35- I have a 60 mile freeway commute to work, so no city driving).
post #4 of 7 (permalink) Old 08-24-2009, 10:42 PM
April 21, 2009 GM issued a service information bulliten for this complaint and dtc code. It was to replace the fuel injectors and reprogram the ECM with updated version. If these were not both done at the same time, the condition will re-occur. Check your reciept from when the injectors were replaced, injector part number should be #12625029. Also check to see if the PCM was reprogrammed.
Hope this helps a little.
chevyrodney is offline
post #5 of 7 (permalink) Old 08-25-2009, 11:13 AM Thread Starter
Dtc1174
Thanks for the info. The car is out of warranty, the injectors were replaced at a local shop. I will look into the service bulletin.
post #6 of 7 (permalink) Old 06-29-2010, 12:48 PM
Anyone have this done under emissions warranty or powertrain? I have the same issue.
chuckie is offline
post #7 of 7 (permalink) Old 11-19-2015, 05:05 PM
Nice post helps me alot thanks.
Йцукенг is offline
2005 Cobalt SS DTC List WopOnTour General Discussion 2 01-06-2016 12:09 AM
15 Dtc pollo8 Problems/Dealer Service 3 06-21-2007 05:34 PM
DTC P0606 Control Module Internal Performance jmc007 Problems/Dealer Service 0 02-10-2006 03:01 PM
