2 gear bog! - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 11 (permalink) Old 06-27-2006, 03:52 PM Thread Starter
2 gear bog!
Hi gang.
My 05 SS has a huge bog after it sits all day at work. I work off a bussy street and i need to pull out and get on it car revs fine in 1st but sone as a stift in to 2nd it will bog untill the RPM's fall to 2200-1500 then bam its off with a normal acelleration.
If i shift slower it not as bad but allways there. I don't notice it in the morning but i pull out of my driveway slower then works. once in second it's fine if i come to a stop and then go it's fine or if it's run for 5 m9inutes before i leave it's fine.
Anyone else have this problem?
Maybe air in the fuel rail? but i would think it be pushed out before i get the 60 feet to the road and it will winde right up in 1st.
44
44dwarf is offline
post #2 of 11 (permalink) Old 06-27-2006, 04:10 PM
Its your computer protecting the motor while its cold. Let it warm up and you'll be fine.
clevelander2002 is offline
post #3 of 11 (permalink) Old 06-27-2006, 04:22 PM
I agree, let it warm up before you go. Also it will help the vapor to run throught your rail so you dont get vapor lock. just good practice to warm the car before you start off.
ChevyTech007 is offline
post #4 of 11 (permalink) Old 06-27-2006, 05:02 PM Thread Starter
I don't think it the temp it happen only in the summer i've checked water temp and at 98 it still did it granted that's still only 1/2 normal but that plenty.
44dwarf is offline
post #5 of 11 (permalink) Old 06-27-2006, 06:48 PM
The car is programmed to keep the motor from fully boosting for the first couple minutes. I had the same problem with my RL.
post #6 of 11 (permalink) Old 06-27-2006, 11:51 PM
iso
iso's Avatar
it's cuz the car has a weak spot in the master slave for the clutch that causes this.
custom valve tap
iso is offline
post #7 of 11 (permalink) Old 06-28-2006, 11:32 AM
Coblasts's Avatar
Can you explain this for me ?
I have noticed this my self it seems to happen only if you punch it.
Could it be a sign of a failure thats waiting to happen?
2006
Cobalt SS Supercharged,Racaro Preformance option
Coblasts is offline
post #8 of 11 (permalink) Old 06-28-2006, 11:39 AM
iso
iso's Avatar
no, you shouldn't worry about it failing. it's just gm's way of cutting corners on the car. the cobalt cup cars solve this problem by using a corvette slave, so even gm knows the stock one is crap.
custom valve tap
iso is offline
post #9 of 11 (permalink) Old 06-28-2006, 01:32 PM
I have the exact same problem, it didn't seem to do it in the winter. I get the jerking (bucking bronco) effect on cold summer starts shifting into 2nd gear. After around 3-5 minutes of driving all is fine.
asstyme is offline
post #10 of 11 (permalink) Old 06-28-2006, 09:01 PM Thread Starter
I only get it once and only if it's sat in the sun awhile.
It will go right to red line in 1st, but shift and bog.
It's got nothing to do with the clutch slave.
Glad to see it's not just mine.
Anyone have troubles with the drives rear wheel bearing going out in 23,000?
44
44dwarf is offline
