Front Wheel Bearings - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 2 (permalink) Old 03-08-2010, 01:05 PM Thread Starter
Angry Front Wheel Bearings
Well I have discovered a design flaw that will drive you nuts. I have an issue with a growling front wheel bearing. When I tried to pull the wheel bearing cartridge I couldn't get ist to move. I removed the spindle housing forging with the bearing cartridge in it and had to use a hydraulic press to get it pushed out. What I found was heavy corrosion in the bore bewteen the I.D. of the spindle housing forging and the bearing race O.D.. If you look at the spindle housing forging there is a relief for the ABS sensor. This relief allows water to pool in the crack between the housing and the bearing. In the winter this a a mix of water and salt. I believe this migrates down between the 2 surfaces and sets up the corrosion that freezes the bearing in place. So in conclusion if you are replacing the front wheel bearing you may have to remove the housing and use a press to push the bearing out.
jrhott is offline
post #2 of 2 (permalink) Old 03-13-2010, 01:25 AM
BlackDragonSS's Avatar
Send a message via AIM to BlackDragonSS Send a message via MSN to BlackDragonSS Send a message via Skype™ to BlackDragonSS
Well that was adressed a long time ago. I had the same problem I had both my front Wheel hubs replaced. Get the sealed ones they last a lot longer and they dont cost as much.
The Skinny:
1980 Chevy Malibu
229 cu. in. V6 (don't judge)
3 spd. Saginaw
15 in. Rally wheels.
Mismatched paint.
A little rust.
BlackDragonSS is offline
front end whtbolttc11 Problems/Dealer Service 0 12-25-2009 11:19 AM
front lip ProjectShastaMcNasty Picture/Media Post 15 12-17-2009 11:25 AM
Right Front wheel clicks. BLT2DRP06 Problems/Dealer Service 30 09-10-2007 07:13 PM
gm front grille? black06sssc General Discussion 6 12-11-2005 11:15 PM
SS front facelift coconut84 General Discussion 35 11-04-2005 01:52 PM
