coolant temperature - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 21 (permalink) Old 03-21-2010, 09:31 PM Thread Starter
Send a message via AIM to unstopable
coolant temperature
Can someone tell me what a stock cobalt should run coolant temp wise?
unstopable is offline
post #2 of 21 (permalink) Old 03-29-2010, 09:35 PM
yea i would like to know to. does it move around like the SRT-4?
ejmonkey3 is offline
post #3 of 21 (permalink) Old 04-01-2010, 09:52 AM
it should be around 80○C or 176○F
Robertg28 is offline
post #4 of 21 (permalink) Old 04-01-2010, 05:38 PM
Mine kinda stays around the 180F range when normally driving....
So that seems about right
post #5 of 21 (permalink) Old 04-02-2010, 01:20 AM
My cobalt runs anywhere from 188 to 212, seems like the fan kicks in around 190 however at crushing speeds 55mph and above with no stops and in overdrive it runs about 190 degrees to 196 degrees consistently.
mikelangelo11 is offline
post #6 of 21 (permalink) Old 04-02-2010, 06:05 AM
yea i was getting out of my car a few days ago and my fan was still on. my temp was 210, so i was drinving around and came to a stop light and it went to 216 but not any higher. so iam guessing from 200 to 216 for my car.
post #7 of 21 (permalink) Old 04-02-2010, 07:26 AM
Wow, you guys temps are all high....If i'm driving it fast or slow it NEVER gets above 190. I have to be in HEAVY traffic for it to get over 200.
bruceg is offline
post #8 of 21 (permalink) Old 04-02-2010, 08:16 AM
Mine is usually around 170-188, depending on outside temp and driving... But 200 ish or 220!!!!. That is a really high temp for your coolant. I think boiling temp for our coolant is around 225-230.....isn't it??
Quietstorm10 is offline
post #9 of 21 (permalink) Old 04-03-2010, 06:37 AM Thread Starter
Also, my low coolant light comes on when I start my car. But after twenty or thirty seconds it goes away... Is this normal? Or is my coolant low?
post #10 of 21 (permalink) Old 04-03-2010, 10:11 AM
sounds like you are a hair low, the coolant sensor is in the overflow tank I believe, I would add alittle bit of coolant there, there should be a line indicator on the plastic housing...
cooling temperature sensor ss4live General Discussion 2 10-03-2008 02:04 AM
Coolant 1BADSS Problems/Dealer Service 3 09-26-2006 11:12 AM
coolant temp richiecall Problems/Dealer Service 7 02-25-2006 09:52 AM
engine coolant heater stiggonometry15 General Discussion 2 07-16-2005 09:23 AM
