Thinking about buying a Cobalt SS - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 7 (permalink) Old 04-11-2010, 03:26 AM Thread Starter
Hello everyone, I am thinking about buying a used cobalt SS. The one I am looking at right now is an 06' manual without the supercharger. I am not really into all the accessories or anything. I just like the simple sporty look with some speed. I was just wondering how the SS model without the supercharger is. Is there anything I should look out for. What are your thoughts on this model for someone who doesnt need an extremely fast car but still wants something fun. Thanks
Sweitz503 is offline
post #2 of 7 (permalink) Old 04-11-2010, 03:15 PM
Uhhh....if your looking at an 06 cobalt SS with NO supercharger it's NOT an SS...they ALL have superchargers if it's an SS...someone is lying to you....
bruceg is offline
post #3 of 7 (permalink) Old 04-11-2010, 03:44 PM Thread Starter
06' ss
I am kind of knew to the SS but I have been searching around a little. I have seen many that say they have a supercharger and that also come with the bigger spoiler. Not sure if that is an option with the supercharger package. Here is the specifications from motortrend.com if it is supercharged I dont see where it says it. And the 2SS says it is supercharged.
2006 Chevrolet Cobalt 1SS Coupe Performance & Efficiency Standard Features
2,384 cc 2.4 liters in-line 4 front engine with 88 mm bore, 98 mm stroke, 10.4 compression ratio, double overhead cam, variable valve timing/camshaft and four valves per cylinder LE5
Unleaded fuel 87
Fuel economy EPA highway (mpg): 34 and EPA city (mpg): 25
Multi-point injection fuel system
13 gallon main unleaded fuel tank
Power: 128 kW , 171 HP SAE @ 6,200 rpm; 163 ft lb , 221 Nm @ 5,000 rpm
Read more: http://www.motortrend.com/cars/2006/...#ixzz0kpWm2bsv
post #4 of 7 (permalink) Old 04-11-2010, 04:15 PM
maybe i'm wrong X.X
bruceg is offline
post #5 of 7 (permalink) Old 04-11-2010, 04:16 PM
I didnt realize they had teh whole 1ss 2ss bullcrap
bruceg is offline
post #6 of 7 (permalink) Old 04-11-2010, 04:17 PM
but anyway...with no supercharger...its going to be FAR from fast...
bruceg is offline
post #7 of 7 (permalink) Old 04-12-2010, 02:32 PM
I had a 2007 SS with the 2.4L and no supercharger. In reality...it's not a fast car. Like it'll beat sunfires and stock civics. It might hang with some stock V6 cars, but it's definitely not anything to shake a stick at. For me, to really pass people on the highway (especially in the mountains since i live close to the rockies) I'd have to drop from 5th to 3rd. If it's just a car to get around then yeah, it's a pretty solid car with some decent power.
It's pretty good on gas. It used only a little bit less than the SS/TC I have now. The engine is pretty durable but obviously try and check for any kind of leak. Punch the thr***le and take note of any smoke coming out the back (black = running rich, lots of white = burning coolant, blueish = burning oil). Check that all the gears are everything are running smooth. The tranny on this car isn't really beefy, but it's adequate for what the car puts out. The clutch is a little spongy but it should feel solid when it's totally engaged.
Go over some bumps and listen for suspension squeaks or any kind of weird behavior. Visually check the shocks for any kind of leakage (at 4 years old it's not too uncommon, but it gives you an idea of what you may need to replace in the near future). Also, when you drive and press the brakes, check for steering wheel wobble or pedal pulsation. I know mine really liked to develop warped rotors.
Other than that I can't think of anything. All of the stuff I mentioned is pretty much just the usual procedure. The only issue I really had with that car is the brake rotors warping every year or so and a squeaky shock. I never had any drivetrain issues. I believe there is a recall to get the power steering pump replaced so you should take advantage of that if you get it.
standard_1664 is offline
Thinking of buying a cobalt ss. 09/2010 Mentalm General Discussion 2 03-15-2010 03:38 PM
thinking about buying a ss blue0453 General Discussion 4 03-14-2010 11:14 PM
thinking of buying a supercharged cobalt?..... dierobotsdie General Discussion 10 08-04-2005 12:57 PM
thinking of buying a cobalt SS Cavalier36 General Discussion 8 06-21-2005 12:42 PM
The wife is thinking about buying a cobalt SS... Gotta0have0boost Off-Topic Discussion 16 03-31-2005 12:34 AM
