'10 cobalt ss/tc oil change - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 9 (permalink) Old 05-26-2010, 09:10 PM Thread Starter
Hey all I'm a new member so please be easy on me. Bought my baby about a month and a half ago and it's close to oil changing time. I was wondering if anyone could tell me how easy it is? I've changed my own oil my whole life and would like to keep that up. I'm not sure exactly where the oil filter is so if anyone has any advice or instructions I'd greatly appreciate it!
Thanks a lot!
brtnsnw4 is offline
post #2 of 9 (permalink) Old 05-27-2010, 09:18 AM
sstupid is offline
post #3 of 9 (permalink) Old 05-27-2010, 09:19 AM
Well, that didn't work. Go to cobaltss . net and look in the "How-To" section. The very first sticky-thread is the oil change how-to.
2008 Cobalt SS SRTC
sstupid is offline
post #4 of 9 (permalink) Old 05-31-2010, 02:03 AM
I found the oil change in the LS to be very easy. It is best to get the special socket for the oil filter, I have read that it is required for the SC cars, not sure about the TC cars.
When I pulled the filter out of the canister lid it splashed oil every where, so make sure you are not holding above the front of the car when you pull it apart.
speed_freak5150 is offline
post #5 of 9 (permalink) Old 06-01-2010, 05:34 AM
well umm the long u drive without changing ur oil......u might crack the engie block and that is going to suck....so change the oil ASAP.......please....or u going to pay 10x more then the oil change for the engine block....so ummm the oil change only like 30 bucks...or just do it ur self...well a quart or oil is like 1.99 each and need like 5 quards...haha well and 5 or 6 bucks for oil filter......hope it helps....
Adamina is offline
post #6 of 9 (permalink) Old 06-02-2010, 06:06 AM
Msfitoy's Avatar
Less than $30 synthetic and filter from WM, one jack + one stand and you're done in less than 20 minutes...
2009 SS/TC full bolt-ons, Trifecta 23psi tune...
Famous last words..."I'm just going to change the wheels and tires...I promise"
Msfitoy is offline
post #7 of 9 (permalink) Old 06-03-2010, 10:55 PM
how do u reset the oil light
cuebalt1 is offline
post #8 of 9 (permalink) Old 06-04-2010, 12:11 PM
Turn the vehicle to the on position with the motor off. As soon as you have done that, press the gas pedal 3 times in less than 5 seconds and that should reset the light. If it doesn't try again and pump the gas pedal faster....
To find out if it worked, after following the steps, turn the vehicle on with the motor on this time and go to the oil change percentage using the O.D.O. button and it should read OIL LIFE 100%.
Hope this helps. IF for if some reason it is different then just read the owners manual.
post #9 of 9 (permalink) Old 06-04-2010, 06:56 PM
thanks streak
cuebalt1 is offline
First Oil change? BrickTop General Discussion 9 06-22-2009 07:23 AM
oil change blackspeed General Discussion 10 07-29-2006 11:01 PM
Oil change on SS S/C 16sy16 General Discussion 15 01-25-2006 03:43 PM
Oil Change 2005 Cobalt RDSCobalt How To: 4 08-23-2005 05:09 PM
New Cobalt SS break-in oil change dervin3 General Discussion 11 05-12-2005 11:21 AM
