something slipping or normal? - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 4 (permalink) Old 06-15-2010, 05:13 PM Thread Starter
Exclamation something slipping or normal?
Just got a '05 SS with 95k miles. Is it normal when going hard up through the gears to see the RPMs "slip"? I've been told the engine needs RPM to build boost, hence the "slipping". BS or normal operation?
ex. shift into second, wide open thr***le, RPM climb to 4,000 then slowly drop to 3,000 then climb back to 5,000 normally* then shift into third. repeat sequence each gear.
*I'm using "normally" to indicate when I feel the car is pulling hard versus "slipping".
Thanks and let me know.
gh0st is offline
post #2 of 4 (permalink) Old 06-15-2010, 05:38 PM
yea no thats not a good thing. it is your clutch thats slipping.
post #3 of 4 (permalink) Old 06-16-2010, 06:29 AM
yeah, sounds like your clutch disc is worn and needs replacement.
post #4 of 4 (permalink) Old 06-30-2010, 09:47 AM Thread Starter
Yup, that's the issue and it's only getting worse. Clutch replacement coming up. Thanks guys.
gh0st is offline
Is this normal? Turbo6 Performance Modifications 17 01-27-2009 01:27 PM
Normal Vacuum Readings? rdyearny General Discussion 9 04-09-2008 11:01 AM
clutch slipping?? cobalt ss 717 Problems/Dealer Service 10 11-18-2005 11:54 AM
Oil Change, is this normal? mx167 General Discussion 21 07-08-2005 08:11 AM
Is this normal? HalfMoon General Discussion 2 07-07-2005 09:47 PM
