10 Car Noises to be Concerned About - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 1 (permalink) Old 07-08-2015, 07:21 AM Thread Starter
With a twist of the key or poke of its start button your vehicleís engine should fire up with the urgency of a physician responding to a code blue.
Of course it should also idle as smoothly as a sewing machine running a line of chain stitches. If this isnít the case you ought to take note because something serious could be awry.
The same is true for the rest of your car or truck. It should operate as silently as a napping kitten and feel smoother than satin underwear. Modern vehicles are engineering marvels built to exacting standards, but as with anything crafted by man, things will go wrong and often in spectacular fashion. If for some reason your car is making uncouth noises hereís a small sample of what could be going on.
1. Hissing
Sure, there might be a bundle of rattle snakes living under the hood but if your car or truckís engine makes a hissing sound it could also be an indication of a leak, either in the cooling system or a vacuum line. If itís the former overheating is a concern, the latter, drivability and fuel-economy issues could result. A trip to the mechanic is in order.
2. Clunking
If your vehicle clunks while driving over bumps or pot holes something is definitely out of order. Chances are itís not a case of roadway elves knocking on the undercarriage, even if these diminutive humanoids are sworn to protect the highways and thoroughfares of America. Moving on Ö
Bad ball joints, worn control-arm bushings or faulty stabilizer link-pins can cause uncivilized sounds, but other chassis components could be to blame as well. Even a loose exhaust system can flop round and make percussive noises.
3. Porcine Squealing
If your carís engine is making a shrieking sound it could be an issue with the serpentine belt. Either the rubber has gotten old and brittle or the tensioner could be failing. If the latter is to blame the belt may not have the appropriate pressure applied to it, causing slippage and ultimately ill-mannered commotion. Fortunately this repair should be relatively simple and inexpensive so thereís no excuse for putting this off. Get it taken care of before the belt snaps or pops off when youíre driving home at 2:00 in the morning during an ice storm, because, you know, thatís when it would happen.
4. Metallic Screeching or Guttural Groaning
If thereís a screeching sound when you apply the brakes itís a good chance the pads have reached the end of their useful lives. Many are engineered with small metal tabs that rub against the rotor when the friction material is worn away to a certain point. The squealing sound is an indication that itís time for a brake job.
If you put off this necessary maintenance for too long the noise could progress to a demonic growling. No, this doesnít mean your car has been possessed by malevolent spirits bent on your destruction. Instead it occurs when the pads have been worn down all the way to the rivets or steel backing plates, a very bad situation. If a similar but less harsh rumbling noise happens all the time while moving it can signal a bad wheel bearing.
5. Clickety-Clack
If your front-wheel-drive vehicle sounds like an Amtrak train while moving at low speed with the wheels turned it could be an indication that the constant velocity or CV joints are failing. Theyíre located on the ends of the drive axles.
And these are some of the hardest working parts in a car. They send power the wheels and deal with vertical inputs from the road all while allowing you to steer. Thereís a lot going on in a small area so cut Ďem some slack. A similar noise coming from the back of a rear-drive vehicle can be an indication of a bad universal joint ...
For the rest of this story, 10 Car Noises to be Concerned About please visit AutoGuide.com.
AutoGuide.com is offline
Assumed Transmission Noises, plz help Brian J General Discussion 0 07-07-2013 07:18 PM
LNF Transmission noises? CobaltCorbin General Discussion 0 04-11-2013 12:02 AM
Service Airbag and weird noises? Tylerml Problems/Dealer Service 0 08-21-2012 11:31 AM
Noises from? rayrayjrc General Discussion 4 07-12-2011 04:24 PM
Squeaks, Rattles and other annoying noises theandies General Discussion 15 08-01-2006 03:36 PM
