c.e.l po230 - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 9 (permalink) Old 01-17-2007, 01:51 PM Thread Starter
Exclamation c.e.l po230
i just have been having a shit load of problems with my car i have a code p0230 which is primary fuel pump circuit malfunction does any one know what that means. or how to fix it. my cars just turning over and over. i posted a thread a lil while ago and some ppl have been helping me out. after my battery went completly dead this happened.
jeffkrivickasSS is offline
post #2 of 9 (permalink) Old 01-17-2007, 05:19 PM
warranty that shit yo!
call your dealer, have them pick it up and fix the dam thing,
06Black is offline
post #3 of 9 (permalink) Old 01-17-2007, 05:30 PM
Heck yeah! GM offers free towing to a certified dealer for warranty stuff!
post #4 of 9 (permalink) Old 01-17-2007, 05:36 PM Thread Starter
cant nothigns stock. its not covered on the warrenty. the. ecu s different, machined s/c snout and a 2.5 pulley. i called they said if its stock they would but not if it was been tamppered with or aftermarket so i think i might be screwed.
post #5 of 9 (permalink) Old 01-17-2007, 05:40 PM
did it mess up anything on the internal engine part??? if not, then no, they cant void warranty. I think they are just being a bunch of dicks.
post #6 of 9 (permalink) Old 01-17-2007, 06:02 PM Thread Starter
no internals, just i THINK either the fuel pump or pcm or ecu. im good on cars but whats the diff. between ecu or pcm? i know thats a dumb question, but they said since its not stock so i dont know.
post #7 of 9 (permalink) Old 01-17-2007, 07:44 PM
Magnuson-Moss law protect you unless all that work was the problem so either way if you have to pay for the fix time they will know what to do. Sorry about your ride sounds sweet and fast.
post #8 of 9 (permalink) Old 01-17-2007, 09:24 PM
pcm and ecu are the same thing just different ways of saying it. Power Control Module, and Electronic Control Unit. Check the fuel pump relay, Im not sure exactly where it is, but if the code derived is from the fuel pump, I would try the relay. Call any AutoZone and ask them for a component location, it may not be exact, but can guide you in the right direction to find where its at. Good luck!
post #9 of 9 (permalink) Old 01-17-2007, 09:51 PM
did u get your pcm from intense? if u did call them up and ask them if they had a power saver built into the pcm.
if they didnt then u will need to get it programmed again
this happens on stock volkswagons all the time
hopefully this is the problem easy fix
