victory_red_SS RWD conversion pics.... - Page 17 - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #161 of 172 (permalink) Old 04-17-2019, 07:59 PM Thread Starter
victory_red_SS's Avatar
Here is a picture of the clearance between my water pump/S/C and my radiator. Plenty of room for my electric fan(s) but not enough room for my drysump oil tank which will be remotely mounted in the backseat area of my car.
Next is the air to air cooler from Vortech which has big 3” outlets. Because of the space between the intercooler and the radiator I am considering another, fan(s) for the intercooler. I will consult with people who have more knowledge than I do.
Next up is a few pictures of some of the supporting components for the HP this car will make. There is the Wilson LS7 intake, the Brodix BR 7 BS 300-B cylinder heads (there is a pic of the valve train specs too) and the Holley 105mm throttle body. On top of the heads I have GM Performance LSX valve covers (the victory red LSX was my doing) which are no longer sold by GM. Looking at the pictures and you can get a good idea of how far back the engine sits. You can also see why I chose the Wilson intake because it fits the space that I have, and it is rated for 1500HP+.
There are also a couple of pictures of the charge piping, but I still need to buy some additional piping to get everything to line up in my engine bay.
The next couple of pictures I took yesterday. I still have to solder the connections. I am going to use the weather pack connections that I scavenged from the original wiring from my car. I am not very experienced doing the soldering so if any of you have good advice/instructions, I am all ears.
I have many other parts that I haven’t add to my picture files. I have all of the wiring harnesses needed to complete the Holley Dominator EFI system. I also have nearly 95% of all parts that bolt to the engine. All internal parts are being bought by the engine builder. At this point I have pre-paid Jim $18,000. for building the engine Including all of my time painting his shop at the beginning of the year and this doesn’t include all of those external components that I have bought from JEGS. I have had people ask me why I would ‘pre-pay’ when everyone else ripped me off in the past. The answer is simple, Richmond Racing Engines is a reputable shop and I have seen his work from the engines being built as well as when they are run on the engine dyno. All, of his work is top notch and he has a long reputation for being honest. Jim evens supports street legal racing by paying the top prize at the 604 Street Legal drag racing series. That means a lot to me. Jim has also referred me to Dwain from Kremyr Racing, the fabrication shop that is going to do the many things that I do not have the skills to do. That work includes the engine mount, the steering rack issues, completing the headers the last guy started, mounting the radiator and intercooler, making a new fuel cell to fit in conjunction with the wheelie bars, the parachute mount, the front support modification and the funny cage bars to allow for a 7.5 second certification. We talked about possibly doing the funny cage bars later and his opinion was that if the car can run that time then we do the bars now not later. Dwain also has a body shop that can deal with my front fenders/body kit that needs to be adjusted to make up for changing the wheel base from 103” to 104.5” which was an issue. I have a certain amount $$ set aside and I will be working my ass off so I will have the rest when it’s time to pay. The good/bad news is that Dwain can’t start until the beginning of July. Bad news because of the delay, good news because it allows me to do the work that I can perform so that we are (fingers crossed) ready to have this car make it to the race track this year. I have worked long hours this past year and I’m going further into debt to finish this project because I am too stupid/stubborn to quit, you choose which one it is.
05 Victory Red SS, RWD conversion, LSX 427, Vortech V7 YSi-B, Ford 9", Holley Dominator EFI ECU, Brodix/Crower/Diamond, ARE Drysump, NHRA certified 7.5 second chromoly frame/chassis/cage
victory_red_SS is offline
post #162 of 172 (permalink) Old 04-17-2019, 08:00 PM Thread Starter
I was just online and I was able to buy both OEM front fenders and a OEM base front bumper facia for $265.00 delivered to my door. These are donor parts that will be cut up to change the openings for the front tires. Because my wheel base was lengthened from 103" to 104.5" this body modification needs to be done to allow the tires to turn properly at the front as well as remove the extra 1.5" gap from behind the tires. The fabricator has a body shop that can do the non-steel welding at the front of the wheels while he will adjust the back part of the fenders. Getting this done was one of the big things on my list and I should have this done in time to put the whole car into a primer coat by the end of May.
post #163 of 172 (permalink) Old 04-17-2019, 08:35 PM Thread Starter
I was talking with the engine builder yesterday and he made the call to scrap the plans to use the SCAT crank that I have. He's going to use the SCAT in a different motor that's making less HP. He has chosen instead to go with a Callies Compstar XL which has just been released very recently. The LS7 version allows for a longer snout which works better with my Vortech/drysump setup. The Callies crankshaft is also internally counter balanced and is designed for high boost and high rpms. The crankshaft will also be paired with Callies Compstar connecting rods. Here is a link if anyone wants to read up on the crankshaft. Callies Compstar CrankshaftOne of the best things about my talk with Jim from Richmond engines was the commitment to having this project at the race track this summer. He said while it would be later in the summer we will be at the track. The fabricator is a good friend of Jim's so they will co-ordinate both of their parts of the project. Next I will have to find someone locally who does wiring so I can get that finished up. I am not interested in towing my car from shop to shop so I will need someone willing to do the job in my garage on a weekend as that's about all the time it's going to take to button up the wiring/soldering.
post #164 of 172 (permalink) Old 04-27-2019, 07:04 PM Thread Starter
My spare fenders and the front bumper surround have come in.
I have an appointment to drop them off on Monday so that everything can be reworked to move the wheel openings ahead by 1.5" to compensate for the stretched wheel base.
I am hoping they will be ready, after my Hawaiian vacation, at the middle of May. Once these are done I will be doing a full coat of primer and getting the car ready to send to the fabricator.
Considering the price I paid for these parts the quality is sufficient to do what I need as once they are cut up the remaining sections head to the recyclers.
And yes I know that isn't a SS front bumper surround but I only need the section that lines up to the fenders.
post #165 of 172 (permalink) Old 10-20-2019, 07:07 PM Thread Starter
Update
While it was 2 months later than expected, the car is in primer and after a short haul the car is now at the shop of Kremyr racing . The deposit at Kremyr' wasn't cheap but I keep hearing that he's awesome at doing his job. This shop is the real deal when it comes to building race cars. Check out their website and for the locals, if you want something done right, call Dwain Kremyr. I was recommended to use Kremyr Racing by Jim at Richmond Racing Engines. These two companies work together and have done so for over 3 decades.
When the car is finished at the fabricators everything short of the engine will be completed. The roll cage (including the funny car bars), the aluminum fuel cell, the steering issues with regards to the alternator in the way of the lower steering knuckle, all of the wiring, the placement of the drysump tank, finishing the headers off and reworking the engine motor mount.
This next stage is going to cost $$$ but it needs to be done and my pain needs to finally be finished so the smile can be realized when I do my first smoke show in front of my house.
There is still a little reworking to be done on the front fenders but that is a 15 minute fix accordingly to the body shop.
When the car comes home I will still need to put back in the complete interior or as much as goes into a tubbed/tube chassis car.
That day was a good day.
The next pictures are from a recent visit to Kreymr Racing.
I was expecting when I got to the shop that I was going to be asked for more money first thing. That didn't happen. In fact, I was shown the work that did happen.
I have to say, Kreymr Racing does awesome work. For anyone local Dwain is the man to do your work.
Dwain has finished the roll cage inside the car which includes the funny car bars around my head. Dwain also did the modification to the cage bar under the hood to accommodate the S/C unit.
Dwain also mounted the radiator, air 2 air intercooler and re-clocked the S/C unit to a better position. This allows me to keep everything under the stock hood.
We also talked abut some venting to help the air 2 air dissipate heat. Pictures of that as we move forward.
post #166 of 172 (permalink) Old 10-20-2019, 07:07 PM Thread Starter
These are the most recent pictures taken while I was at Kremyr Racing. Dwain asked me to drop off some parts and while I was there I took some pictures of what they has done in the past week.
They have been working on the steering rack.
They had to change the geometry/alignment to make way for the alternator which I need as a bolting spot for the Vortech S/C. Because I am only running the alternator off of the serpentine belt, Dwain re-positioned the alternator and we will get the different sized belt. All of the extra pulleys/tensioners are then added to my list of parts I need to sell.
If you look at the bare steel parts you will see the modification needed to allow for my drysump to mount where the A/C unit would be.
They have also been working on the charge piping for the S/C'er
The Vortech kit doesn't fit under my hood the same as it does under a stock '13 Camaro SS hood. However, Kremyr made easy work of making the needed piping that the kit didn't provide. Once I have powder coated the new pipe it will look like this kit was designed for this Cobalt SS.
This last picture shows how Dwain decided to provide more venting for the intercooler. Once it’s done it will look almost normal. My goal has always been to keep the body as stock as possible. Kremyr Racing also re-clocked the S/C so that everything sits under the stock hood.
I have been talking to a race transmission expert and while my 2 speed Powerglide is race prepped with after market components it is still the stock housings. He doesn’t believe the stock housing can hold the type of pressure that my project needs for the expected HP level.
After checking in to the various transmission I had talked with another expert. The higher the gear ratio the weaker the transmission. The 180° gear ratio is rated to somewhere between 600-800 HP. That's not enough for me. I did find a Rossler Terminator 6 on RacingJunk.com. This transmission exceeds what my upper limits are and is a top-notch product.
I will also order the Mark Williams coated billet yoke for this transmission. The transmission is ready for pickup and soon off it goes to the fabricators. The transmission details are what follows:
ROSSLER Terminator 6 - Powerglide:
- ROSS-LOCK Pro Tree transbrake
- Oversized billet steel clutch hub
- 10 clutch Promod drum
- Max surface HD band
- Front pump low friction bearing kit
- Sonnax Super Hold Servo
- Billet aluminum dual ring servo
- Modified front pump converter charge system
- Pump gear lube system
- 1.69 Promod straight cut gears - cryo treated option
- Vasco billet output shaft
- REID RACING 2-piece SFI case
- REID RACING SFI GM/Chevy bellhousing
- REID RACING XHD tail housing with roller output bearing
- Rollerized entire case
- Deep finned cast aluminum pan, +2 quarts
- TH400 style oversized bolt-on stator tube
- "NASA" A
BONUSES and upgrades that come with the transmission:
- Cryogenic gear treatment option
- LOKAR locking dipstick - fluid level set by Rossler
- Temperature sensor bung welded to the oil pan
- Energy Suspension polyurethane transmission mount
- 6AN in/out trans cooler fittings
Next up for the project is the mounting of the drysump 2 gal US tank which Dwain believes they will manage to mount under the hood to the frame rail.
The project is finally making good headway. I stop in at Richmond Engines this week to see where we are with the motor.
post #167 of 172 (permalink) Old 10-22-2019, 04:52 PM Thread Starter
Another piece of the puzzle has arrived into my hands, in fact 2 pieces of that puzzle. I have to say that the Reid case on the Rossler transmission is really nice. While it is strong enough to be SF! 4.1 and 30.1 certified it is light enough for me to pickup off the ground. I ordered a Mark Williams yoke and the u-joints today and once I have those they and the transmission go to Kremyr Racing and Dwain measures up the driveshaft length.It is obvious that this transmission as never been used before. With that said I did realize today that it will need to be re-certified sooner than a new one as it was built 09/16.The next part is needed to help me get in and out of the car easier. I was not originally going to use a quick release hub on my steering wheel but the funny cage bars changed that plan.
post #168 of 172 (permalink) Old 11-23-2019, 01:14 PM Thread Starter
I have been in touch with the editor of LSX Magazine and he has asked to do a feature story on my project when we are done. I had told him that Holley LS Fest West was something I wanted to attend. He offered to do a full photo shoot if I make it to Vegas this coming April!
I have talked to Kreymr Racing and I have talked to Richmond Racing Engines. They are both on board to make this happen.
I have talked with my wife and she is on board with changing our 2020 vacation plans so we can be in Vegas for the LS Fest West.
Besides the photo shoot there will also be drag racing and I have every intention of participating. I am going there fully tuned and ready for balls to the wall racing.
I have never made a deadline before.
I have never been this close to finishing before.
I have never had these shops working on the project before.
Now the shops also have something riding on me getting to Vegas, their names will be prominently be featured in the feature story covering all most 14 years of the cars life.
I expect updates to be very regular for the next few weeks.
There will be plenty of odds and ends to be done once the car comes home so time for me will pass quickly.
If any of the members want to see the car up close, finished and racing LS Fest West is the place to be in April.
It would be really awesome to be able to race some Corvettes and Camaros while I am there.
A couple of other wrinkles that I must iron out in short order.
Because the car chassis and most RWD components were originally planned out with the intention of using a turbo LSJ we weren't worried about all of the torque at launch. Now that we have the boosted V8 I investigated my drag strip Ford 9" and checked out it's capabilities.
The 35 spline axels are good, the spool is good, but the Strange case and the gears aren't going to work. Not at 1200+ HP. Dwain Kremyr is ordering up a new rear end next week which will have a 4.11 gear ratio and be able to more than meet my needs. He also believes he has a buyer for my strange rear case with 4.30 gears.
The other issue I have is that my MagnaFuel 750 EFI fuel pump is not designed for continuous use which will severely limit any kind of street driving. I am choosing to swap out that unit for a Holley 12-1800-2 which will satisfy both street and dragstrip needs.
One other piece of the puzzle arrived a couple of days ago.
They are supposed to hold way more HP than I am going to throw at them which I'm pleased about.
Diamond piston specs;
Diamond Chevrolet LSX 12°, 4.125 Bore, 4.000 Stroke, 6.125 Rod, 1.15 comp height, -4.8cc, .927 x 2.250 pin
LSX RACE 12°FLAT TOP SERIES
· 3D milling on piston crowns for ready to install finish
· Inboard forging design with fully machined under crown for maximum strength
· Valve pockets designed to work with most aftermarket 12° cylinder heads
· Side gas ports for better ring seal
· Moly skirt coating for friction loss and skirt wear protection
· Top ring down dimension: .280" (1.115cd) .250" (1.053cd)
· Ratios figured for .053 head gasket
· Premium 1.5mm x 1.5mm x 3.0mm ring package included
· Premium H-13 .250W wrist pins included chamfered for round wire locks
· Valve pocket depth: 0.220" intake and .162" exhaust
· 2618 material for High HP-NOS-Boost applications - rated for 2000HP
· 10.7 compression ratio on 72cc combustion chambers
post #169 of 172 (permalink) Old 01-18-2020, 11:23 AM Thread Starter
UPDATES
I am batching all of the updates for the past couple of months. While I know this forum no longer gets much traffic the updates are for the lone people who still come here.
I am happy to share that one of the stumbling blocks for building the motor has been removed. The LSX block has been drilled for the 1/2" head studs. Because the high nickel content LSX blocks are harder than others and because these are not common blocks the info on how to drill and tap them for the 1/2" head studs is less than standard.
Having said that, Kyle, at Richmond engines, has now gotten these holes drilled and tapped and I couldn't be happier. Kyle has also bored out the cylinders to 4.125", drilled out and installed the lifter bushings and drilled out the oiling holes in the valley of the block. For some reason GM only had one drilled out while the others weren't but they are now.
The Callies Compstar crankshaft arrived and it was finished at the factory after Jim sent over the bob weight. The quality is what is needed for this amount of HP.
post #170 of 172 (permalink) Old 01-18-2020, 11:23 AM Thread Starter
Next, over to Kreymr Racing to talk with Dwain and hand over more $$$ and that's ok because everything they do is top quality. I can't really afford them, but I also can't afford to not have them do what they do best.
The wiring has started and should be completed in short order. The plan with the wiring guy is to keep working with minimal days off between now and New Years. In the pictures the black box in the center of the dash is the Holley Dominator ECU. The fuse panel is also installed as is a second panel for relays.
One thing that I probably couldn't afford to do or do without is a center console. Dwain really came through on this part. The pictures don't give the complete look because the dash is off for wiring. I like where the rocker switches are mounted, and I really like the look of this console. The whole interior is going to be either victory red or black, so I need to choose a color for the console. Because the carpet will be black, I am favoring red for the console. The roll cage, which is red, is going to be painted black and the silver parts on the dash are also going to painted red. I have the same color scheme in the engine bay except for a few components which will be silver (including the super charger). I am up for feedback on the color of the console.
Another item almost done is the wing for drag racing. This wing is mounted to a trunk lid specifically for the track. I still have the original trunk lid and wing which will be swapped out for street driving.
Dwain has also redone the mounting points for the parachute as well as the parachute deployment lever. I like the positioning and the functionality of it, requiring only a forward motion to deploy.
Under the hood, Dwain has mounted the dry sump's oil tank. It is going to take some adjustments to the radiator and the water pump to allow for the routing of the hoses but the quality of workmanship that Dwain and Scott do, means that it will look like everything was always designed to be there.
Another item that needed some thought was were to mount the relocation brackets for the smart coils. Those are likely done now and will be mounted to the underside of the cowling. We have changed the plan for the required windshield wiper (we’re using a single blade) so the wiper assemble is gone making the room we needed for the brackets.
I also took a picture of the Vortech racing bypass valve sitting in its proper place. This bypass valve is almost twice the size as the one that comes with the kit. Again, it looks like it was always supposed to be there.
The last thing is another big milestone to me which I already shared but this time I have the picture to share, my NHRA 7.50 chassis certification. :thumbsup:
[/URL
On sell: HID Xenon bulbs and Xenon HID Conversion kits autocarextra General Discussion 0 04-18-2007 07:17 AM
3rd brake light led conversion domin8_gt General Discussion 25 02-24-2007 10:26 PM
victory_red_SS is going RWD victory_red_SS Performance Modifications 11 02-23-2007 09:49 AM
victory_red_SS project update and pics victory_red_SS Performance Modifications 5 09-06-2006 06:36 PM
Twin Screw Supercharger Conversion Demand DarricksZ28 Performance Modifications 30 02-21-2006 01:33 PM
