victory_red_SS RWD conversion pics.... - Page 2 - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #11 of 164 (permalink) Old 12-09-2007, 08:44 AM
very nice job
nightmistwalker is offline
post #12 of 164 (permalink) Old 12-16-2007, 05:33 PM Thread Starter
victory_red_SS's Avatar
More about my project
Here are some more components of my project.
Powering my engine are these two lovely snails. The larger is the GT-45 and the smaller is the GT-28.
I have two different set of custom rods, one from Macias Racing and 2 sets from Pauter Machine. I am actually building two engines so that I have a spare.
The following picture is the initial design for my turbo header. We are waiting for the chassis and engine placement to be finallized before the rest of the header is to be done.
This is one of two Turbo Switching Valves, which will be used in the sequential turbo setup. The white cotton looking material is aerospace grade insulator which withstands temperatures in excess of 1,000*s.
This unit is a totally custom Boost Swithcing Unit that will operate the aerospace transducer and turbo switching valves.
The following pictures are some parts that have come back from being coated.
The pistons received better than a ceramic coating, they received a zircon-ceramic coat, which is similar to diamond dust, and the piston skirts received the anti-scuffing coating. The valves all got the zircon ceramic coat, as did the intake, exhaust runners and the combustion chambers of the cylinder head.
The shiny coating on the valve cover, front cover and the sides of the head is an Aluminum flake coating, which in person is supposed to be even shinier and cooler than the pictures show. The engine block is still being done and we should have that back next week. This aluminum flake coating is supposed to be superior to powder coating as it is impervious to the elements. If oil gets on the engine, I have no idea how that would happen, it is just a matter of dish soap, water and a tooth brush to clean it up. Degreaser is a no-no.
If you look at the picture with the pistons next the head, you can compare the polished piston to the new coating.
Here are some of my parts to help with cooling. The ribbed tubes are the equivalant of Laminova tubes. The Meziere water pump is one of two we will be using. One for the intercooler and the other in place of the stock water pump. In addition to those parts we are using a customized "Supercooler" that will produce 800 watts of cooling power.
Meziere water pump
Supercooler
Bully Clutch has come aboard as a sponsor and will be supplying me with clutches. This clutch will allow for street driving but I will need to adjust my driving style when in traffic.
A.R.E. Dry Sump Kit
SFI Approved McLeod Bell-housing
Here are my custom billet cams. The custom grind was done by Bates Engineering. The specs are
INT 221 @ 0.050" - 275 LL, max. lift 467.0"Vlift @ 1.7:1 - Config Stock Centerline 10 Retard Cam Timing Intake
EXT 221 @ 0.050" - 275 LL, max. lift 467.0"Vlift @ 1.7:1 - Config Stock Centerline 6 Retard Cam Timing Intake
These are the cylinder sleeves we are using , also from Bates Engineering.
05 Victory Red SS, RWD conversion, LSX, Procharger F-1R, Ford 9", Bigstuff3, NHRA 8.5 second chromoly frame/chassis/cage
victory_red_SS is offline
post #13 of 164 (permalink) Old 12-16-2007, 05:33 PM Thread Starter
Stainless Steel Brake Company were the only ones who were able to supply us with the big brakes needed that would fit behind a 15" wheel for my slicks.
These are the custom seats for the car but I will be changing the suede in favor of leather.
The car will be street driven but will need to be setup for the track which means swapping out the Pro Street carrier and axels to a strictly drag racing set. Once this is done the car will be trailered to the track in my matching trailer.
post #14 of 164 (permalink) Old 12-17-2007, 06:33 PM
CoBIZZLE's Avatar
Send a message via AIM to CoBIZZLE
Awesome!!!
CoBIZZLE is offline
post #15 of 164 (permalink) Old 12-18-2007, 06:45 PM
So what are we going in the motor home or the 2500HD? nice seats and trailer!
ssnipes is offline
post #16 of 164 (permalink) Old 12-18-2007, 06:50 PM Thread Starter
It will be a faster trip taking the truck and the gas mileage will be a bit better.
The motorhome will be more comfy but the wife is concerned about adding a quick 10K kms onto it.
I can put a bed in the trailer so you can spread out sleep when it's my turn to drive
post #17 of 164 (permalink) Old 01-06-2008, 04:17 PM Thread Starter
I just got some pictures of the block after the coating process.
It is a bit of bling but the price was right.
post #18 of 164 (permalink) Old 01-06-2008, 06:43 PM
K is there any updates? I am bored and want to read my fav online mag!
ssnipes is offline
post #19 of 164 (permalink) Old 01-06-2008, 07:05 PM Thread Starter
We will know tomorrow what we are doing about the crankshaft.
At the very least, we will order the 2.2 crank/pistons/rods/wrist pins/rings from the 1400hp Ecotec Build and get the first engine built.
I will also be having it out with conversion shop, letting them know how thoroughly pissed off I am about the lack of progress on my car.
The only one who has been keeping their end of the deal is JBP, all the other shops are getting an earful tomorrow.
post #20 of 164 (permalink) Old 01-06-2008, 08:21 PM
shit what is wrong with your money? what more do they want. send them a fridge and tell them it will be filled when they are done with the car.
ssnipes is offline
On sell: HID Xenon bulbs and Xenon HID Conversion kits autocarextra General Discussion 0 04-18-2007 06:17 AM
3rd brake light led conversion domin8_gt General Discussion 25 02-24-2007 09:26 PM
victory_red_SS is going RWD victory_red_SS Performance Modifications 11 02-23-2007 08:49 AM
victory_red_SS project update and pics victory_red_SS Performance Modifications 5 09-06-2006 05:36 PM
Twin Screw Supercharger Conversion Demand DarricksZ28 Performance Modifications 30 02-21-2006 12:33 PM
