09 cobalt sound system help - Chevy Cobalt SS Forum : Chevrolet Cobalt SS Forums
post #1 of 2 (permalink) Old 04-28-2012, 10:37 AM Thread Starter
i just purchased an 09 cobalt ls 4 door and have a 12" pioneer sub that i wanted to put in it, im pretty new to all the sound system stuff and was needing to know if it was possible to put it in without having to replace the whole system seens how ive come to enjoy the sound it has i just wanna make it hit a little harder. I would appritiate some advice on the matter. (I can post pictures if wanted/needed)
timmtimm07 is offline
post #2 of 2 (permalink) Old 04-29-2012, 05:01 PM
You can buy an adapter that you can splice into the rear speakers and output as the RCA out. Wire up the amp like you would with an aftermarket but connect the RCAs to the adapter instead of the back of the deck. The next issue you will run into is how to turn off the amp when the radio is off so you don't drain the battery. We found a wire under the passenger door that will do the trick. You will need to test the wires to make sure it is actually off when the car is off and then connect to one that does. The other option is setting it up as a toggle switch. But that isn't as nice looking. There are probably other ways people have done it but that is what we did before I put in an aftermarket radio.
SupremeSlacker27 is offline
Simple Sound system question unstopable General Discussion 3 03-27-2010 05:28 PM
F/s Huge Sound System : Cheap ATXSLOWBALT06 Parts Wanted/Parts for Sale 1 04-23-2007 11:57 AM
Pioneer sound system THEDUKE General Discussion 12 08-08-2006 03:24 PM
Sound System HELP 06CobaltSSS General Discussion 5 03-27-2006 08:24 AM
Sound System SpAwN General Discussion 10 06-07-2005 11:30 PM
