The auto door lock on ignition works only for the driver side door.. I an usually careful enough to check all the locks.. but this is a safety issue.. should I call a locksmith and have it fixed?
When you want to find a locksmith you need to mention where are you located. If you are in GTA area, you can call locksmith Toronto and solve the problems.
The last time i called for their help, they came quickly and helped professionally.
