Well I alot of you asked about rubing with 235s. Well here is your ansser.
The rims I used are 18X7.5 42mm offset. Stock is 18X7 40mm offset.
Yes and no.
Here is what I mean.
I had a problem with them rubing and You can see this in the pics.
I also have a fix for it that you can see in the pics.
Ok here is the ONLY rubing problem I had.
This happend at about 2/3 to the lock the first time a backed the car up with the new tires and rims.
And I fixed this by taking the wheels off and using a heat gun to sofen the plastic and puting two screws in to hold it away from the tire.
There where no other problems with it rubing any where els for the 250 or so miles I drove it with the new rims and tires.
Now I do not have a lowering springs on the car yet and might not for a while.
Ill keep you all updated if I have any more problems.
Later
Yes and no.
Later
