So I’ve replaced everything I could think of in my ac system and it just blows hot air, I’ve replaced compressor, pressure switch, weather control unit, system was drained and charged to spec multiple times. Blower motor blows strong resistor pack has been replaced recently. I’ve seen talks of a blender door problem if not a filter screen that gets clogged in the system those have not been replaced. Clutch for Compressor engages cause i hear my RPM’s change when turning it on condensor fan works, back then I would turn it on and when parked would blow cold air but any form throttle from peddle would immediately shut it off I need some help
