Aftermarket H/U Installation
53147 Views 55 Replies 27 Participants Last post by  TRAVIS71
14
Last week I put in an Alpine H/U. My particular model does not have an internal amp, so I used the stock amp by running the preouts to the speaker level outputs of the amp (essentiailly the stock speaker wires on the harness). This also allowed me to continue to use the stock sub. I attempted a lot of tiral and error and will add all that I have learned. Excuse how dirty my car is.
To get to the radio first remove the silver trim panel above the glove box.
Open the glove box.
Pull the panel off from the bottom.
Panel Looks like this. If it doesn't match put it back haha :p
Next pop the top edge of the trim piece below the steering wheel out and then remove the trim panel with the driver control center buttons. It is on the left of the radio trim piece and right of the steering wheel.
You will have to pull on the tab, shown in the picture below, to remove the center trim panel. It is the only real place to get fingers behind and pull. It is possible to pull some on the bottom, but I was never successful. The trim piece resists strongly, but didn't break. It may need to be worked awhile, but it will come off.
Here is how it looks once the trim and radio are removed. Four screws hold the radio in. The wiring harness adaptor ($5 from a local place I have connections) is plugged in for a test look. I removed all the excess wires I didn't need after this.
I removed the Stock Reciever relocation plug (used for recievers that have driver info built in). Can't think of anything else I removed, but don't remove the power antena/remote line of the harness. They are needed to turn on the factory amp (I made this mistake, but luckily kept the wire).
Here is the factory radio removed.
Now its time to play with the wires.
This is normally straightforward, but I'm going to go over it anyway.
Yellow on the adaptor harness goes to the constant power of the h/u harness
Black on the adpator goes to the groud of the h/u harness.
Blue is a power antenae lead or as used in the Pioneer system a turn on for the factory amp. This will attach to the remote line of the h/u harness. If you need to run any other amps connect their remote lead here as well. Use a twist cap, so remote lines can be added that do not run through the harness. It makes removal and install easier.
There is no turn on/ignition lead to turn the h/u on and off with the harness. These new radios use a fancy bus system to turn on. Another member here has mentioned the only way to utilize this with an aftermarket radio is to buy a harness costing over $100. I am bypassing this system for that reason and some would consider it "ghetto", but it works. To turn the radio on and off with the car run a wire from the ignition fuse in the fuse box to the ignition lead in the h/u harness. Use a twist cap here as well.
I tried searching for a switched wire on the inside of the car, but gave up after a half hour or so and hooked it to the fuse. I plan on going back and searching some more. This would give a cleaner install.
See less See more
21 - 40 of 56 Posts
i work at bestbuy... in car audio... we dont carry the kit or the harness... i can order it and pay $86 (our cost), $199 regular...
ima just order it from cobaltaddiction i guess
Ahhhh thats the harness that uses the existing turn on system. The harness I got bypasses that by hooking up a remote turn on hooked up to accesory power. What Cobalt Addiction has is what I got.
Hey man, awsome thread. I sent u a msg cuz i had a couple questions about my own project.
later
wow
it took me 35 minutes tops to install my kenwood h/u and i dunno about you guys, but that how to made things look WAY more difficult then it actually was. would have been done soon but i was wiring in my subs at the same time to it took a little longer :)
It isn't overly complicated, but it is a step by step how to. I included all the information I thought could be useful. The only real complicated part is creating the new harness. I spent a lot of time making sure I installed everything right and could write this how to. I spent about 2 hours total on the project, but could do it again in much less.
Couple questions I'm curious about:
Do you have the 7 Speaker Pioneer System?
Did you use my tutorial to help you?
just so you know.. there is one turn-on wire in the car. it is lokated in the ignition harness. look for a harness under the dash right behind the key. it has about 5 wires in it. hit the brown wire. make sure first but that should be it. it worked for me.
Damn that looked really complicated lol. Probaly because I haven't taken a high interest in systems and what not. Really good do it yourself thread though ;).
hey guys, thought id add to this. im putting in a HU and went to best buy for the adapter box to get rid of the stereo and keep the dic.... well best buy doesnt carry these for our models. there carry the older ones pre 2005 (least thats what the guy told me). he said they had wired the stereo in manualy on a cobalt and wired in the dic, chimes and stuff with out the box. but i didnt risk it, i had delt with the stock stereo wired in under my drivers seat in my truck, im not doing it again.
so anyway i then went to crutchfield and talked to chad online and then called him. they just made this box, its still new so its not on the site yet. its part number: 120993303 and it cost me 129.00 usd...
also if u ever need to replace the front door speakers get the 5 1/4 set
you will then have to cut off the speaker off from where the supports meet the outer ring, so infact thats all you have is just a ring left. then align your speaker, mark and drill the holes and attach new speaker to that ring. i used my dremmel for this whole preocess, the speaker is mostly plastic, so youll be fine. then mount it back in with sliding bottom in first and then put back in the top screw. i didnt have time to take pics... sorry
if you dont understand, pm me and i will try to explain better. i have a bad time with typing.
See less See more
i dunno if its been said on here, its long thread, but DO NOT connect the blue/white wire called "power antenna". if you hook it up your gauge cluster will SHUT DOWN. just somethin i figured out from a few installs :)
Mine is connected with no problems. I Don't know how you are turning on the amps without it, though? It is the remote turn on lead for the factory amp.
He was wrong, I work at Best Buy and we do have them! SOrry bout the douchebag... ours are $120.99.
yeah. no power antena here! :D
I have a Cobalt LT 2006..do i need a separate modulator/harness other then the wiring harness? I used to have a 2004 cavalier and that needed a separate harness otherwise the car would not start with an aftermarket H/U.
Depends on where your Driver Information Center is. On the SS/SC it is in the dash, so there is no need to worry about the stock h/u. I am not sure if the DIC is located there for all of the Pioneer systems and I don't know if you have a Pioneer system either. If you don't have a Pioneer system you will most likely need a relocation harness of some sort. I've heard from some retailers that there is a kit in the works by Metra with a screen and buttons to replace the in radio DIC. But it could be awhile and will most likely cost some dough.
Greets,
I have an 04 Malibu Maxx LT...we have a problem similar to you all with the DIC, GM Lan, etc. Would something like this be of any help?
http://www.scosche.com/scosche_caraudio.aspx?CategoryID=5&ItemID=GM1593B
Yeah that would be the replacement for those that have the DIC integrated into the radio.
nice step by step but i wanted to know if you had to do anything to get your trip gas mileage or oil life to work right
No, with the Pioneer system all of that is in the gauge cluster.
Went to a few shops, some local, some big chains. Everyone wants to sell me a whole new system when all I wanted to do was go a little louder on the 7 speaker pioneer. Just a little more volume. Any suggestions w/out changing the whole system?
A good properly tuned h/u may help. What are you looking to be louder? Bass, highs, etc.
21 - 40 of 56 Posts
