have taken 5 nuts off alloy wheel rim.why doesn't wheel come off car?
G grirob · Registered Joined Sep 11, 2017 · 2 Posts Discussion Starter • #1 • Sep 11, 2017 have taken 5 nuts off alloy wheel rim.why doesn't wheel come off car?
LouisSS · Registered Joined 3 mo ago · 4 Posts #2 • 1 mo ago You have to kick the tire out from the inside, the rims stick to the base due to heat and corrosion. That's normal.
A Austin Hale · Registered Joined 1 mo ago · 8 Posts #3 • 29 d ago Wheel adhesion generally occurs because corrosion accumulates between the rim and the hub. Try to use a cooper grease to resolve this problem.
