1 - 18 of 18 Posts
hey! i just got a BOV but where i went to install he told me i cant because the tube is in plastic what did u do to make it work and installed properly? if i just replace it where the the orignal car BOV is, is it going to work properly and make the sound its supposed to? o do i absolutely have to buy the a metal tubing to replace the plastic one? if so how is that called? thanks in advance!
I honestly wouldn't put a aftermarket BOV on your TC..... If you install a good intake such as the K&N 69-4518TTK you'll get the sound you're looking for!! I don't have an external BOV and my car sounds awesome!!! I'd return it and get the K&N system, I have them in stock as well!
Kind regards,
Jordan Priestley
Yea you cant put an aftermarket BOV on the stock piping. You have to get new piping with a flange to add the BOV. And there isnt a BOV that will work the same place as your stock one.
Thanks, but how much does it cost a new piping with a flange? and what is that thing people are saying: somettin block (i forgot the word) ? do i need it too?
block off plate. Yes you will need that. Or you can do what Magna flow said and keep your stock BOV. Get a intake and charge piping and you will hear it alot better.
I know that I don't have the TC and this is what I am curious about:
If you do the intake and charge piping, I know that you would hear the whistle from the TC but would you hear a nasty little grimlin shriek with the stock BOV??
That is what I would make the TC sound like the first day I would get one. Like:
Whaaaaaaaaaarrrrrrraaaaaaa. Pshhhhhh-EEEEEELLEEEEEEEEEWWWEEEEELLLEEEE!
Yea your going to hear it stock, but not as good as you would with charge piping and intake with the recurc hose. all that is, is the extra air going back into your intake.
no, you have to get a aftermarket bov to make it loud or louder then stock.
not true i had a modified air box before i go the hahn intake and charge piping, and i heard a vast improvement of bov noise just from the air box mod, no real power gains to speak of but huge improvement as far as noise goes
Not so true yourself, Yes your going to beable to hear the differance after you add both the charge piping and intake yourself in your car. But someone on the side of the road isnt going to beable to hear that bov unless you have an aftermarket bov.
once again not true significant increase in noise inside car and outside of the car, sounds completely different
much bigger difference if you switch to a bov from the stock bpv that is on the turbo ill agree with you there but just modifying the intake box will get you some decent sound from the bypass valve
Discussion Starter #15
Can anyone tell me where I can buy the piping in metal for the bov with a flange because the only one I found is worth 500 on the net! Thanks for ur hekp ?
Discussion Starter #17
Perfect but how much u sellin each? And wat comes with them? Are they brand new or used? And how much for shippin to montreal canada? Thx for ur help!
1 - 18 of 18 Posts
