Ok I have an 2009 cobalt ss. I recently changed the clutch out for a spec stage one and just replaced the release bearing due to it grinding. The problem I have been dealing with is no matter how much I bleed it manually I can't get it to build pressure there are no leaks and I even replaced the clutch pipe but no luck. Any suggestions?
did you figure this out?? i just replace the transmission, clutch, and flywheel. wont go into gear while on and will go into gear while off??
