1 - 8 of 8 Posts
My check engine light comes on when I run regular and also the car sputters I run premium and it runs like a top what is that?
never knew that I've gone from hondas to truck to a cobalt had no clue
actually the manual says it should run on regular no prob. but if you ru on premium you get the most power out of it, so i always go with premium
When your car gets a lean knock, it reports it to the ECM. Quit being cheap and buy the right gas. I have a solution though. Fill it up with 93. At 1/2 tank fill it with 89. That will make it 91. Next 1/2 fill with 93 then after that 89. That's what I do.
It's not even a matter of being cheap the salesman that I bought it from specifically told me to use premium. now the problem gets even weirder at 3/4 of a tank Check engine light comes on at 1/3 it goes off thats using premium
1 - 8 of 8 Posts
