Scourge said:
Some other things to consider. Will your transmission be compatible? For example, will the flywheel spin the same direction? Will it even be in aligned the same way? (for example FWD may have flywheel facing he left/right side of car while RWD may have it face the back of car) Will you need different motor mounts? What needs to be relocated?
Are you able to just use the supercharger itself?
Unless he's already got an Ecotec, which I don't think he does, it would probably be easier to buy a whole motor and modify it, like one from a wrecked Cavi, to handle boost and all that good junk. It's always touchy to swap a new motor into an older car, especially when the new motor is so different from the old motor. I know they're both I4's, but I'm not sure the rest of it would match up, the tranny that you point out would be a great question. I swapped the T5 from a '92 Camaro into my '90 Camaro, because the 700R4 automatic that I had built before the V6 came out and the V8 went in, guess what? There's not way on earth to make a 700R4 from a V6 fit to the V8 that I had. They were both Chevy's, everything came from Camaros that were seperated by just a couple of years, but the V8 had a much wider angle than the V6 did between the cylinders. My dumb ass never had a clue. Like people said, anything can be made to fit. You'd probably have a much easier time, and cheaper, to buy a new car. You can get a used Redline soon, and in a year or two longer you can get a used Cobalt SS. I wish I would have bought a new Camaro with the V8 already in it, with the 5spd, and started with that. I would be up about $2000 right now, but this is the first 'nice, new' car I ever owned. So I'm keeping her till she dies from rust, and lemme tell ya, there are alot of replacement parts for a '90 Camaro.
