looking down into the handle you will see a plastic plate with a clip, carefully pry the clip up with a flat head screw driver then undo the screws underneath. on the onside door release, take the plastic plate off of behind it using the same screw driver. now follow the side of the door and remove the tabs holding it in place. after you have that done, lift up from the handle carefully to watch the wires...
thats pretty much it.
if you have manual windows you need to go buy a special tool to take the clip off behind the winding arm and take off the winding arm.
