1 - 20 of 33 Posts
Sorry its visual only lol I still think it looks awesome though :D
nice touch!
looks better...did you do a bit of prepping first? or use any high temp primer/gloss coat?
Discussion Starter · #4 ·
for the coil/plug cover I just used brake caliper paint. The ecotec supercharged cover I used the same paint just had to prime it first.
should have went with carbon fiber would have added at least 10 hp :D
just kidding looks good
Looks nice, let us know how it holds up.. I want to do something like that, plus some serious polishing. However I don't think black would look as good as blue, or red, so I need to decide what off color I want to go with.
Discussion Starter · #9 ·
lonewholf , I bet this same red I used would go great with black
Bud, I was just thinking the same thing... ;) Red and black look beautiful together.. I think you just convinced me :D Let me know if you notice in peeling or flaking after you put a few hot miles on her :)
Discussion Starter · #11 ·
After one night, I've noticed nothing flaking or peeling. Still looking brand new. It looks so good in person, looks factory. This red shines great also. It's plasticoat red brake caliper paint rated to 900 degrees. If you do the ecotec supercharged cover also you need to prime it first.
Looks good, I have been thinking about doing the same to mine, but in Blue, Now I am convinced, I will surely do it in a week or so.
Good Job.
Thanks for the info... What brand primer did you use?
I need to pick up some of that caliper paint anyways becuase I want to do my calipers too :D
Discussion Starter · #14 ·
I don't remember the brand. It was just some cheap grey primer from walmart. worked great :D
WTF are you talking about? Any moron knows that CF adds at least 15hp and 20lbs of torque... :rolleyes:
A sticker on the painted surface would have netted an additional lb of boost, due to heat deflection as well...
Seriously, looks tiz-ight... Seems like it matches the car in those pics pretty good.
be sure to lightly sand the area first so that the paint "sticks" better.
Discussion Starter · #17 ·
so long as its high temp I don't see why it wouldn't hold up
Discussion Starter · #18 ·
Lonewholf said:
Anyway dervin3, you were right, it looks great! I used a different type of paint though, so hopefully it holds up :)
as good as it looks in pictures, you oughta see it in person ;)
Yep, seeing it in person... I used the Ceramic High Temp(1200 Degree) engine paint made by Duplicolor. I have used it before, and it has held up pretty well, so we will see :)
Discussion Starter · #20 ·
the red and black combo is HOT too! i'm lovin it
1 - 20 of 33 Posts
