I heard rumors of people adding making plans to add turbos ontop of the super or some other setup, and as i sit here looking at my engine i cant help but wonder if the turbo wouldnt do any good cause the air still has to go at the speed comming out of the super(at max 12 psi).
If u set the turbo at a higher psi you'd be wasting the use of the turbo cause id backfeed into the super, and if u reverse it u have the turbo set lower the super charger is basically sucking it off
, and if u set them the same it achieves nothing(i think).
for example;
now: intake
v
super @ 12 psi
v
engine geting 12 psi boost
w/turbo: intake
v
turbo at any given psi (ex. 14)
v
super @ 12 psi
v
engine still getting 12 psi boost
Or am i just ignorant and overlooking somthin...
any help appreciated
for example;
now: intake
v
super @ 12 psi
v
w/turbo: intake
v
v
super @ 12 psi
v
