I have been having a problem occasionally when I am shifting into 1st gear especially, it happens especially when I am easy on the gas trying to get off to a slow roll kind of start.
While I am holding at the friction point the car will feel like it has caught so I start to release the clutch. The car will start to jump as if I were flooring it then releasing the gas and repeating. I have noticed it in a few gears (but mostly just 1st), and I know they are poor shifts but this seems to be exaggerated from what I am used to.
I have to this point always driven Hydraulic Clutch cars (I believe this is an electronic clutch, correct?) so I am used to the clutch catching right when you let up the clutch pedal not halfway through.
As of now I am not too concerned about it, I'm just figuring I'm getting used to the new clutch type. Is this normal for the car or should I be concerned about this?
I kinda went through the same thing when i first started driving mine. It just takes some getting used to. The clutch in our cars suck as well.
Ok that's good. Cuz I was driving an auto Blazer before that for about a year and when I 1st started I was like, "Damn, I forgot how to drive a stick!" If I were to upgrade to a performance clutch would it solve that or would it still do it? Is it the clutch itself or the other components that are cheap?
It will probably still do it but not as bad, and you will get alot better power transfer to the wheels. I believe its just the clutch, but if you get a high perf. clutch, i would definetely upgrade the flywheel and all that. I haven't had to many probs with mine, but it did slip a couple times when I was racing. I have 15k on it
the new clutch will help, i know when i first started to drive my car it would do the same thing. but it was the first time i have ever driven a clutch too. after you get used to driving the car it shouldnt jump anymore, are you not giving it the right amount of gas as your letting the clutch go?
Yeah, that's it because I'm trying to get off to a slower start I'm giving it less gas. I have driven many stick cars before and if I had done the same on them then it wouldn't have acted weird at all. It sounds like it's a common problem people have had while adjusting to this car so I'll just give myself a little more time to adjust.
