Is it because of a bad battery or wiring problem if my headlight turns on when set to low beam but doesn't always turn on work when set to high? its flickering and i cannot pinpoint the cause. I wanna try to fix this on my own if its not that complicated.
Not sure how the cobalt headlight is set up, but check to see if you have an loose wires in the harness, behind the headlight. Sounds like a loose wire.
@goaliemo sorry for the late response. I'm going to check if there's any loose wires in the harness. thanks!
