1 - 1 of 1 Posts
Brand new Crane Ignition Hi6 Di² CD. This one we have had for a while now but Does not work correctly on the SRT-4 as of yet but crane is working on it.
We waited for awhile to see but news today is forcing the sale.
will sell for $450 shipped.
Also have a seperate dual channel trigger available for $150 shipped. (black Box). perfect for DIS ignition cars.
This is the Red in colors box with trigger. Plug n play. \
(Neon 1995-2000)(Mitsibishi cars)(Saturns)
"ANY DIS ignition retard piggyback computer for Neon's and DSM's will work for Saturn with a little hot wire technique"
SCDYNE
HI-6DI2 CD Ignition for Distributorless Engines:
• HI-6DI2 designed for distributorless 4 cylinder ignitions
• Built in two stage rev limiting can be set via rotary switches in 100 RPM increments from 600-9,900 RPM. No Chips!
• Fully sealed with soft urethane to protect against vibration, dirt and moisture
• Fully digital, CD ignition with multi-spark
• Tach check accuracy built in!
• NEW! Easy Checking for System Problems! No guessing! Built-in flashing codes tell what the problem is. Checks coil, ground, power supply, loose or broken wires and the ignition unit itself!
• Module triggered, easy installation with “Plug-n-Go” harness.
• Perfect for nitrous, turbo vehicles with optional 0-20°adjustable timing retard and MAP sensor. See here for options.
• Exclusive cross fire protection for supercharged or turbo applications
• Sequential rev limiting stops harmful “popping and banging” at limit
• Multi spark generates up to 12 powerful sparks per cylinder firing
1 - 1 of 1 Posts
