i have not done it but i kno some ppl on the site have. i believe you need a pully puller i think intense makes one
I've TONS!
6-8 on my car plus just about as many on 3 other ss/sc's
yes you have to take the blower off...no its not hard.
you remove the intake, unplug the sensors on the SC, undo the 4 allen head screws that hold the blower on. DONE!
you do need a pully puller tho.
i use the BilletFlow unit becase quite simply its the best unit out there. we did 30+ pulls on it before i had to replace anything on it!!!!!
i think i have some pics on my laptop...or at least on my home desktop.
you can post or PM if you have any other questions.
how did you hold down the supercharger off the car
as far as hold it in place when takeing the pully off?
if so....you just get a friend to hold it down while you turn the pully puller.
close to the topic of pulley's:
do any of you know if the SFPH pulley's will bolt up to the same set up as the stage 2? i want to put the 2.8" pulley on, but am not sure what else should be replaced. i see they offer a dub ring or pulley ring, is that needed if i allready have the stage 2? also, will the stage 2 injector be suficient or should that be changed to the 60#, plugs? just looking for some info
thanks
