How can I bleed off the fuel pressure in the fuel rail without running the car until it dies? I know I can remove the pump fuse and then idle it until it starves, but I don't want to run the motor. Is there a port that I can open to do the same? I need to fix an injector that the retainer clip has somehow come off at the fuel rail port. There is so little room do it in place, so it will have to be done after pulling them all off together.
Just like you said, pull the fuel pump fuse and run the car till it dies. Or find the fuel rail service port and use a pressure gauge to relieve pressure
