Not even close I'm afraid.
Open the glovebox and remove everything from the inside
Look on the right of the box you should see a plastic tab with a "string" attached, disconnect that string and the glovebox should drop down.
Look in the back above the fan motor you should see a black plastic door, snap it down and you should see the air filter is inside
Pull it out, replace and reverse the above to reassemble.
Enjoy your filtered air :)
