1 - 8 of 8 Posts
I need some help and cant find the answer to this anywhere. I have my TC/SS in teh shop right now (day 2) getting the LNF upgrade. they had everything done the first day but when we went to test it out we lost the turbo.
The found a hose loose so they replaced it. Did it again and the same problem only dont know if its a hose loose or what.
The car is very sluggish and when the boost hits around 4lbs (thats it!) I loose my Turbo.
Anyone have this problem or know what the answer might be or maybe even where to look for it?
Thank you
Hmmmm, seems like you are in a pickle there....
That shop should be fixing the problem and see if you can get more info from these guys so the members here that are experienced in the LNF can further help you. A loose hose should not be the main problem, may be something bigger than that.
Have them check the wiring to the new map sensors. One of the sensors only uses 3 of the 4 wires in the connector. If they swapped connector wires 2 and 3, which could be easy to do because of the sorta confusing picture in the directions, you will get all sorts of problems. It should set a check engine light, that should point them in the right direction. Sorry about the car, ive done lots of there gm lnf upgrades and havent had any problems.
Did anyone ever find out what was causing this? I did the LNF upgrade on my TC/SS about a year ago and it ran perfect for 6-8 months. Then all of a sudden one day, without any check engine light, I start having this problem! This is incredibly frustrating because the issue happens for a couple days and then goes away. In the meantime, the check engine light comes on sporadically and doesn't appear to be directly linked to the boost issue. This issue has been on and off for the past 3 months and I've had the car in the dealership more than 10 times to have them look at it... still no permanent solution.
PLEASE HELP! This is honestly making me want to sell my car it's so annoying!
not to sound like an asshole but the lnf upgrade from chevy is the biggest most expensive rip off and all i have heard about them is problems take the car back get it removed get ur money back and go get a ZZP tune or a trifecta tune
1 - 8 of 8 Posts
