so ive got a 05 ss/sc...kinda been doin things to make it look good but now im wantin some go fast goodies that wont break the bank to bad..got any tips or ideas for me..like to run a 2.5 pulley what else do i need..any advice would be apreciated
i was lookin into like a stage 5 kit but i may have to settle for less bcuz of being kinda broke right now...any ideas where to find the best prices
If your gonna get a smaller pulley, you will need supporting cooling mods. Wouldn't go any lower than a 2.6. If you do go that low though, I'd recommend Meth inj, bigger HE, and Dual Pass. Definitely gonna need bigger injectors and exhaust.
Cheaper route is to get a stage II kit. Check with ZZP to get staging ideas
right on well ive got the ehaust covered..so i should start with buyin like a 2.6 and 60lb injectors then the other shat..wonder what stage tune i would need with those
****erformance stage kits are amazin they have the canned tunes so you dont lean out with the smaller pulley like some other venders
but 2.6 /2,5 is really low and on stock m62 will generate alot of heat
min i would sat 60# injectors
second intercooler
meth or dual pass or both
flat out the more cooling mods you have the better
meth will alow you to run more timing and more boost safer
and a set of interceptor gauges to mon. IAT2
