i have a 9007 set of HID's no highbeams. you get use to it though theres plenty of light. But all 9007's will work.
You should remember from NECO, Silverstars are the way to go! HID xenon bulbs aren't effecient unless you retrofit an HID projector. To get the best out of your stock halogen reflector lamps, use Sylvania Silverstars!selfinfliction said:i'd love to have actual hid's, but when we're talking about $15 for xenon, or $300+ for hid's.... i think i'm going to go the cheaper route and spend my cash on go faster material lol
Mercury said:You should remember from NECO, Silverstars are the way to go! HID xenon bulbs aren't effecient unless you retrofit an HID projector. To get the best out of your stock halogen reflector lamps, use Sylvania Silverstars!
selfinfliction said:i think that's a little early to say when not many people know everything about these electrical system, don't you
Not really because the wiring to the headlamps wasn't desigined for an HID system. It was designed for a 55w halogen bulb.selfinfliction said:i think that's a little early to say when not many people know everything about these electrical system, don't you?
GoofyGuy said:still your a frigin genious arent ya. My HID system uses a 35 watt ballast. All HID system use less wattage then stock bulbs. So theorticaly its better for the sysem.![]()
GoofyGuy said:It would make more heat if it were using more power. Like the 100w bulbs will melt a system down.
