NO NO NO NO NO. DO NOT GO THAT SMALL!!!! I would say the smallest you could go safely with alky injection is probably 3.0"
If you want to go to a 2.8, you're just asking for trouble by upping the boost that much. A 2.8 will require extensive PCM tuning and depending on how well the IC really does work, it might need alky injection as well. A header and full exhaust work will probably be mandatory to keep the exhaust from backing up and causing "boost stacking" which will give you serious knock retard. But do NOT go that small until its been proven what mods are needed to run such a small pulley safely. Let the pros at Modern or Gravana or any other shop be the ginuea pigs for that kinda stuff unless you got the money to buy another motor.
Just my $.02
Just my $.02
