1 - 1 of 1 Posts
AWHILE AGO: my car started acting up, the cruise wouldn't work, and RPM's wouldn't drop when fully engaged clutch. I replaced the old Clutch Safety Switch. It went back to normal.
RECENTLY: My car will only work normal when I remove the battery harness, to allow the codes to clear from the ECM. The Codes eventually stack and stack p0833, until finally i get a check engine light. Its no way to drive a cobalt SS, very shifty.
WHAT TO DO:
I will Replace the bottom switch again tomorrow with a new one. 5 dollars from rockauto
I heard there is a second Switch ,the clutch position sensor, where do I buy this online?
Can i replace it myself, and then just remove the battery harnessed to clear any codes?
Please help.
1 - 1 of 1 Posts
