Recommend this becomes a sticky....
This was taken from:
http://www.chevroletforum.com/recalls-and-tsbs/make_CHEVROLET/model_COBALT/year_2006/TSB.htm
2006 Chevrolet Cobalt
Bulletin #: 3688
Sequence #: 10017263
Date: 01/01/1901
Component Name: 134000 visibility:sun roof assembly
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Sunroof switch bezel falls from the headliner. *tt
Bulletin #: 050232005A
Sequence #: 10017497
Date: 11/01/2005
Component Name: 010000 steering
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Ei05093 - clunk in steering system at slow speeds while turning and/or driving over bumps. *tt
Bulletin #: 050138016
Sequence #: 10018663
Date: 11/01/2005
Component Name: 353600 equipment:electrical:air conditioner
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Water leaking on front passenger side floor of vehicle, water blowing out of vents (seal heater core cover). *nm
Bulletin #: 3421B
Sequence #: 10014807
Date: 01/01/1901
Component Name: 110000 electrical system
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Engine stalls, loss of electrical systems, and no diagnostic trouble code (dtc). including 2005-06 pontiac pursuit. *tt *sc
Bulletin #: 3641A
Sequence #: 10018563
Date: 01/01/1901
Component Name: 022000 suspension:rear
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Rear suspension squawk/squeak over bumps. *tt
Bulletin #: 3687
Sequence #: 10016948
Date: 01/01/1901
Component Name: 020000 suspension
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Clunk noise from front of vehicle during turning maneuver. *sc
Bulletin #: 3757
Sequence #: 10018645
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Sunroof inoperative binding or stuck. *tt
Bulletin #: 050601027
Sequence #: 10017819
Date: 09/01/2005
Component Name: 060000 engine and engine cooling
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Revised camshaft position actuator fastener installation procedure. *tt
Bulletin #: 050730015
Sequence #: 10017537
Date: 06/01/2005
Component Name: 103000 power train:automatic transmission
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Hard to shift or select vehicle gear, shifter sticks/binds/jams. pontiac pursuit (canada) 2005-2006. *tt
Bulletin #: 050730016
Sequence #: 10017512
Date: 11/01/2005
Component Name: 103100 power train:automatic transmission:control module (tcm, pcm)
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Transmission control module (tcm) shorted to battery voltage during diagnosis and/or service. *tt updated. *nm
Bulletin #: 05083
Sequence #: 10017079
Date: 08/01/2005
Component Name: 353500 equipment:electrical:navigational system(global positioning system)
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Onstar system inoperative. *sc
Bulletin #: 05084
Sequence #: 10017470
Date: 09/01/2005
Component Name: 121000 exterior lighting:headlights
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Daytime running lamps inoperative - customer satisfaction program. *tt
Bulletin #: 050850011
Sequence #: 10017498
Date: 09/01/2005
Component Name: 221700 seats:front assembly:seat heater/cooler
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Revised front heated seat control module replacement. tt
Bulletin #: 050864030A
Sequence #: 10017765
Date: 11/01/2005
Component Name: 162300 structure:body:door
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Interior door handle inoperative or clicking noise heard when opening door. *tt update. *nm
Bulletin #: 3261B
Sequence #: 10018551
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: (retained accessory power) rap deactivates from drivers door only. *tt
Bulletin #: 3310D
Sequence #: 10017261
Date: 01/01/1901
Component Name: 061000 engine and engine cooling:engine
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Service engine soon (ses) light due to a p0171 - inspect air intake and oil dipstick. *tt
Bulletin #: 3385A
Sequence #: 10016549
Date: 01/01/1901
Component Name: 115000 electrical system:fuses and circuit breakers
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Repeated park lps fuse open (additional information). *tt
Bulletin #: 3393A
Sequence #: 10017006
Date: 01/01/1901
Component Name: 120000 exterior lighting
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Backlighting is inop during daylight conditions (headlight switch turned on manually) *sc
Bulletin #: 3433
Sequence #: 10017032
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Service engine soon (ses) light and severe engine misfire on cylinders 1 and 4 or cylinders 2 and 3. *tt
Bulletin #: 3506A
Sequence #: 10018530
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Incorrect mileage displayed after programming a new bcm. various models including 2005 - 2006 pontiac pursuit (canada only). *tt
Bulletin #: 3512B
Sequence #: 10016533
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Service engine soon (ses) light due to a p1182 diagnostic trouble code - potential causes and issues. to include 2006 saturn ion. *tt
Bulletin #: 3562C
Sequence #: 10018539
Date: 01/01/1901
Component Name: 063000 engine and engine cooling:exhaust system
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Service engine soon light due to p0420 diagnostic trouble code on low mileage vehicles - update ecm calibration. *tt
Bulletin #: 3627
Sequence #: 10018624
Date: 01/01/1901
Component Name: 071110 fuel system, gasoline:storage:tank assembly:filler pipe and cap
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Fuel tank is slow to fill and/or dtc p0446 - inspect evap vent pipe. the ses lamp may be illuminated due to a p0466 dtc. *tt
Bulletin #: 3628
Sequence #: 10018543
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: P2431 diagnostic trouble code after ecm replacement - inspect ecm part number. *tt
Bulletin #: 3635
Sequence #: 10016534
Date: 01/01/1901
Component Name: 036000 service brakes, hydraulic:antilock
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: No communication with anti-lock braking system after ebcm replacement. to include 2006 chevrolet hhr. *tt
Bulletin #: 3642
Sequence #: 10018533
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Ses light with a p0230 dtc and no performance concerns - replace ecm. *tt
Bulletin #: 3644
Sequence #: 10018532
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Momentary sag on light to moderate accel when cold - valve deposits. *tt
Bulletin #: 3646
Sequence #: 10018604
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Ses light due to dtcs p1516 and p1682 - ecm calibration pending. *tt
Bulletin #: 3648
Sequence #: 10018915
Date: 01/01/1901
Component Name: 114100 electrical system:wiring:front underhood
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Hesitation on acceleration after internal engine repairs - check injector harness orientation. *tt
Bulletin #: 3673
Sequence #: 10019203
Date: 01/01/1901
Component Name: 185000 vehicle speed control:cruise control
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Cruise control inoperative and/or malfunction indicator lamp on with diagnostic trouble code p0833 stored. the condition may not be able to be duplicated by the dealer yet the consumer may have a repeat concern. *ak
Bulletin #: 3786
Sequence #: 10018600
Date: 01/01/1901
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: No start after engine harness replacement (non-abs). *tt
Bulletin #: 3799A
Sequence #: 10019210
Date: 01/01/1901
Component Name: 141100 air bags:frontal:sensor/control module
Make: Chevrolet
Model: Cobalt
Year: 2006
Summary: Sir light on/service air bag warning message with diagnostic trouble code b0081. *ak
