ok now i put 8000k hid kits in the balt for the high and low beams of my halos and they still arent any good. as of vision.
so how can i adjust them so i can see farther?
i hear people say adjust them and it will improve the vision.
because now on my low beams the vision is cut off at angles. its hard to explain so ill take pics tonight.
or is there a way to keep the high and low beams on at the same time?
is would be even better
most hid kits unless there bixenon you will lose your brights. As far as adjusting your HIDs you really can't. 8k you loose some of your brightness. The rule of thumb is the higher the Kelvin the less amount of light. The only real thing to do is adjust the headlhgt angle but then you might piss alot of ppl off at night
