I bought a pulley last year and I never got the screw's that came with it. Just wondering where I can maybe buy them?. Or do I just use the same one's?.
If its the GM hub your installing it on then just go to lowes and get the following hex head screws. 6mx1.0x16mm I had to shave off about 1mm of material from the end so it wouldnt cut into the nose of he sc. I also like the fact that I can now use a 6mm allen wrench to remove/ install a different pulley.
can you not just get 6mmx1.0x15mm
I looked for the 15mm length bolts, but they went from 10 to 12 to 16mm and up. Kinda strange, looks like they would go in 2mm or 5mm incriments.:confused:
Why can't you just use the stage 2 bolts if you replace the pulley?
