how do i remove the rack n pinion mounts or whatever it is so i can drop the sub frame on my car? i knw where the sub frame bolts are but i can only find 1 bolt for the rack n pinion steerin any help would b great thanks guys
They bolt from the top down, at the ends of the rack near the boots. Might be easier to just remove the tie rod ends from the knuckle and remove the steering intermediate sahft bolt and bring the gear out with the subframe. You will have to remove the trans mount and slide the gear out the wheel opening if you want to remove it from the subframe.
