Does anyone know if you need a piston tool to reset the piston on the caliper for the rear brakes on a 2007 Cobalt SS Supercharged coupe? I replaced the front brakes and used a "C" clamp to compress the pistons but I'm not sure about the rear. Thanks, Tom
All you need is a pair of channel locks and needle nose pliers. Channel locks to twist the piston loose, needle nose pliers to screw the piston beck into the caliper. Dont forget to loosen the reservoir cap first and apply pressure while screwing to piston into the caliper.
