pulled this off the site........very good numbers.
http://www.redlineforums.com/forums/showthread.php?t=534
I think that depends on the car. The lighter the car the less torque matters (IMO). Of course its important, but on a 1000 pound car I'd want more HP then torque, as torque is what gets you going and HP keeps you going (if you want to put it that way)SRT-MAN said:hpis good but torque is better.
true! true!Fatal Fax said:I think that depends on the car. The lighter the car the less torque matters (IMO). Of course its important, but on a 1000 pound car I'd want more HP then torque, as torque is what gets you going and HP keeps you going (if you want to put it that way)
But would you rather have a redline with 200 lbs of torque and 150 hp? Or you would rather have a redline with 200 hp and 150 lbs of torque? I always thought that in a 1/4 run, that torque was more important over hp??? Or was I miss led?Fatal Fax said:I think that depends on the car. The lighter the car the less torque matters (IMO). Of course its important, but on a 1000 pound car I'd want more HP then torque, as torque is what gets you going and HP keeps you going (if you want to put it that way)
HP, is a measure of torque produced over the RPM range. So you can't prefer one over the other. What you're saying is that you'll take a car with more or less low/top end. That's why low-torque cars can rack up horsepower numbers if the engine has no revlimit (which of course they all have)CD'srt said:But would you rather have a redline with 200 lbs of torque and 150 hp? Or you would rather have a redline with 200 hp and 150 lbs of torque? I always thought that in a 1/4 run, that torque was more important over hp??? Or was I miss led?
Nick,Nick Fury said:Ahh, ok then, I didnt know the redline dyno numbers where to the wheels. I had seen some other redline wheel dyno numbers they were down in the 170's or so.
thats not bad if the redline is dynoing that close the SRT's should be a damn good race when they line up.
Edit:
Heres the link to where I saw those other numbers earlier..
http://redlineforums.com/forums/showthread.php?t=405&page=1&pp=10
