Latest update......The KAM Keep alive memory was getting thrown b/c the battery cable was loose and the PCM was loosing consistent power. <----that was just the start to the problems!!!!! After we got that fixed, the light came back on again
this time i took matters into my own hands and scanned the code myself, after taking a look at the sensor and the harness, i noticed the wire harness was up against the housing of the supercharger, it had wore thru the insulation causing the sensor to be grounded out, this was causing the sensor to read -40 farenheight. I then took it to the dealer to see if they would figure out what was wrong with it...........the did not impress me musch by telling me the computer is saying "description unavailable".......i then pulled my scanner out of the trunk, scanned the code and pointed it out to a "T" what was wrong
<-----this was the guys face!!!!, Others of you out there check this harness to make sure it is not so tight that it is upagainst the S/C. The harness is located toward the passenger side of the car, and the harness runs under the S/C close to where the pulley is. Dont take anything to Southtowne to get fixed!!!!!!
