XeroState said:
No kidding. Blowing hot air into the engine will kill power..considering dyno's don't have blowing air on them (other than fans, which don't work like real air). I'd still like to hear from SFPH tho about this, as they seem to be ignoring the question on the redline forum, which is why I posted it here too.
XeroState, normally on any Forced Air Induction engine , you must first take the necessary precautionary measures against excess heat intrusion into the engine , by making a few changes. One of them is changing the factory restrictive air intake system, to a less restrictive system, to let the added air flow into the engine.
Secondly, you should either (dependant upon size of smaller SC pulley) change the stock sparkplugs over to one range colder and close the gap, to lower cylinder temperatures. Thridly, is is like I mentioned in the Redline Forum, you must check your Air/Fuel Ratio numbers to make sure they are well inline of not being pon the Lean side ( 11.5 to 12.0 )
If after making these changes, then no increase in boost pressure is present, then a Boost Bypass is needed to allow the boost to increase (but at a safe level). Anything over a 2 lb. increase in boost, should have a Safe Computer Tune, to make sure the vehicle is not leaning out, that could cause, not only excessive knock retard, but also severe detonation and grenading of the engine.
However, a couple of people out in Texas have already done these modifications to attain 2 to 3 more lbs. of boost and are not having any problems so far. Also, we do not have any Dyno Results to report , but there are a couple of companies who have already purchased our pulleys that are having Dyno Tune Sessions in the next couple of weeks.
As soon as these results are in, we will post them accordingly. Hope this helps, as we are certainly not selling "Snake Oil" to the Supercharged Engine owners, just to make a "Quick Buck". Instead, we are offering a quick solution to making the needed horsepower levels, each Enthusiast desires to have.
For the past 7 years SFPH has been coming out with newer products for all Foreign & Domestic Supercharged Engine Owners and we have not failed in our quest, for them to achieve the horsepower produced by our smaller supercharger pulleys, with the proper tuning etc. to make this happen.
You might be limited in running higher levels of boost at this time with the ECU limited it, but shortly there will be several companies offering a solution, as to how to overcome these barriers and give everyone the performance they want.
Also, check out our new page:
http://www.southfloridapulleyhq.com/SFPH/rl_csss/ps_dub_system.htm
